Tuning antenna function through hydrogen bonds to chlorophyll a - Laboratoire brestois de mécanique et des systèmes Accéder directement au contenu
Article Dans Une Revue Biochimica biophysica acta (BBA) - Bioenergetics Année : 2019
We describe a molecular mechanism tuning the functional properties of chlorophyll a (Chl-a) molecules in photosynthetic antenna proteins. Light-harvesting complexes from photosystem II in higher plants - specifically LHCII purified with α- or β-dodecyl-maltoside, along with CP29 - were probed by low-temperature absorption and resonance Raman spectroscopies. We show that hydrogen bonding to the conjugated keto carbonyl group of protein-bound Chl-a tunes the energy of its Soret and Qy absorption transitions, inducing red-shifts that are proportional to the strength of the hydrogen bond involved. Chls-a with non-H-bonded keto C131 groups exhibit the blue-most absorption bands, while both transitions are progressively red-shifted with increasing hydrogen-bonding strength - by up 382 & 605 cm-1 in the Qy and Soret band, respectively. These hydrogen bonds thus tune the site energy of Chl-a in light-harvesting proteins, determining (at least in part) the cascade of energy transfer events in these complexes.
Tuning antenna function through hydrogen bonds to chlorophyll a.pdf (4.32 Mo) Télécharger le fichier
hal-02281193 , version 1 (18-11-2020)
Manuel J. Llansola-Portoles, Andrew A. Pascal, Manuel J. Llansola-Portoles, Fei Li, Pengqi Xu, et al.. Tuning antenna function through hydrogen bonds to chlorophyll a. Biochimica biophysica acta (BBA) - Bioenergetics, 2019, 1861 (4), pp.148078. ⟨10.1016/j.bbabio.2019.148078⟩. ⟨hal-02281193⟩
109 Consultations
77 Téléchargements
