Journal articles
L'humanitarisation du sacrifice musulman. ONG confessionnelles et recompositions rituelles
Abstract : Based on fieldwork studies conducted on several faith-based NGOs (France, Turkey), this paper analyses the humanitarian practice of Muslim sacrifice. It emphasizes the reasons and stakes behind this “humanitariza­tion” of a ritual endowed with a complex status in contemporary societies. By turning the sacrifice into an act of solidarity and aid towards the most needy, but also into a lever for development within beneficiary countries, this humanitarian practice restores the meaning of a ritual otherwise con­fronted with multiple constraints and transformations. The humanitarian management of the sacrifice denotes the ritual’s conversion to a technical and logistical process, hence questioning the mutation of ritual norms and practices due to global dynamics.
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-01476846
Contributor : Olivier Givre Connect in order to contact the contributor
Submitted on : Tuesday, April 19, 2022 - 12:32:47 PM
Last modification on : Tuesday, April 19, 2022 - 1:06:23 PM
File
L_humanitarisation_du_sacrific...
Publisher files allowed on an open archive
Identifiers
Citation
Olivier Givre. L'humanitarisation du sacrifice musulman. ONG confessionnelles et recompositions rituelles. Journal des anthropologues, Association française des anthropologues, 2016, Craquelures globalisées du religieux, pp.29-55. ⟨10.4000/jda.6487⟩. ⟨hal-01476846⟩
Share
Metrics
Record views
198
Files downloads
2
