Preprints, Working Papers, ...
Some regrettable grading scale effects under different versions of evaluative voting
Abstract : Many voters seem to appreciate the greater freedom of expression afforded by alternative voting rules; in evaluative voting, for example, longer grading scales and/or negative grades seem desirable in so far as, all other things being equal, they allow greater expressivity. The paper studies to what extent the behavior of voters, and the outcomes of elections, are sensitive to the grading scale employed in evaluative (or "range") voting. To this end, we use voting data from an experiment conducted in parallel with the 2017 French presidential election, which aimed to scrutinize the negative grade effect and the length effect in grading scales. First, this paper confirms that the introduction of a negative grade disfavors "polarizing" candidates, those whose political discourse provokes divisive debate, but more generally we establish that it disfavors major candidates and favors minor candidates. Second, under non-negative scales, polarizing candidates may be relatively disfavored by longer scales, especially compared with candidates who attract only infrequent media coverage and who are little known among voters. Third, longer scales assign different weights to the votes of otherwise equal voters, depending on their propensity to vote strategically. Overall, we observe that the benefits of the expressivity provided by longer scales or negative grades need to be balanced against the controversial advantage these give to minor candidates, and their tendency to undermine the principle that each vote should count equally in the outcome of the election.
Document type :
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://halshs.archives-ouvertes.fr/halshs-02926780
Contributor : Nelly Wirth Connect in order to contact the contributor
Submitted on : Tuesday, September 1, 2020 - 9:22:44 AM
Last modification on : Wednesday, November 3, 2021 - 6:20:16 AM
Long-term archiving on: : Wednesday, December 2, 2020 - 12:59:47 PM
File
2024.pdf
Identifiers
  • HAL Id : halshs-02926780, version 1
Citation
Antoinette Baujard, Herrade Igersheim, Isabelle Lebon. Some regrettable grading scale effects under different versions of evaluative voting. 2020. ⟨halshs-02926780⟩
Share
Metrics
Record views
233
Files downloads
235
