Gradient-Based Algorithm with Spatial Regularization for Optimal Sensor Placement
In this paper, we are interested in optimal sensor placement for signal extraction. Recently, a new criterion based on output signal to noise ratio has been proposed for sensor placement. However, to solve the optimization problem, a greedy approach is used over a grid, which is not optimal. To improve this method, we present an optimization approach to locate all the sensors at once. We further add a constraint to the problem that controls the average distances between the sensors. To solve our problem, we use an alternating optimization penalty method. As the associated cost function is non-convex, the proposed algorithm should be carefully initialized. We propose to initialize it with the result of the greedy method. Experimental results show the superiority of the proposed method over the greedy approach.
