A bacterial protein targets the BAHD1 chromatin complex to stimulate type III interferon response - Groupe Pathogénie Bactérienne / Bacterial Pathogenesis Group (IBS-PATBAC) Accéder directement au contenu
Article Dans Une Revue Science Année : 2011
Béatrice Regnault
  • Fonction : Auteur
Andréa Dessen
Intracellular pathogens such as $Listeria\ monocytogenes$ subvert cellular functions through the interaction of bacterial effectors with host components. Here we found that a secreted listerial virulence factor, LntA, could target the chromatin repressor BAHD1 in the host cell nucleus to activate interferon IFN-stimulated genes (ISGs). IFN-$\lambda$ expression was induced in response to infection of epithelial cells with bacteria lacking LntA; however, the BAHD1-chromatin associated complex repressed downstream ISGs. In contrast, in cells infected with $lntA$-expressing bacteria, LntA prevented BAHD1 recruitment to ISGs and stimulated their expression. Murine listeriosis decreased in BAHD1$^{+/-}$ mice or when $lntA$ was constitutively expressed. Thus, the LntA-BAHD1 interplay may modulate IFN-$\lambda$-mediated immune response to control bacterial colonization of the host.
Science_2011_post-print.pdf (2.22 Mo) Télécharger le fichier
cea-00819299 , version 1 (26-07-2020)
Alice Lebreton, Goran Lakisic, Viviana Job, Lauriane Fritsch, To Nam Tham, et al.. A bacterial protein targets the BAHD1 chromatin complex to stimulate type III interferon response. Science, 2011, 331 (6022), pp.1319-21. ⟨10.1126/science.1200120⟩. ⟨cea-00819299⟩
265 Consultations
585 Téléchargements
