Understanding ribosome binding interactions and conformational changes of the EngA bacterial GTPase, a potential target for new antibiotics - Groupe Réponse immunitaire aux pathogènes et au soi altéré / Immune Response to Pathogens and altered-self Group (IBS-IRPAS) Accéder directement au contenu
Thèse Année : 2016
Intéractions avec le ribosome et changements conformationnels de la GTPase bactérienne EngA, une cible potentielle pour de nouveaux antibiotiques
The development of new therapeutics against bacterial infections has aroused great interest over the last years in the context of drug resistance. The starting-point in the pursuit of new antibiotics for which bacterial resistance mechanisms do not exist is the identification of novel cellular targets. Genetics studies in the early 2000s have identified engA as a conserved bacterial gene whose product is a GTPase that could represent a potential drug target: it is conserved among bacteria, essential for cell survival, and absent in humans.Since EngA acts as an assembly factor for the bacterial ribosome, one of our aims was to develop an assay to screen inhibitors of the EngA-ribosome interactions. These interactions are modulated by EngA conformational changes that are in turn triggered by the binding of different nucleotides to the catalytic G-domain. As the interplay between all these events in bacteria is still not resolved, we have used a multi-technique approach to explore these questions in order to obtain useful information for the setting up of a robust screening assay.SAXS and limited proteolysis showed a conformational change occurring in solution upon addition of either di- or tri-phosphate nucleotides. While model validation analysis confirmed the GDP-bound conformation, the GTP-bound state does not match any known EngA structure. Binding studies have revealed modulation of interactions by different nucleotide-bound states. Furthermore, response to nucleotides occurs at high concentrations, suggesting that the role of EngA in promoting ribosome assembly could be monitored by the intracellular nucleotide concentration. Efforts on identifying the GTP-bound state 3D structure by crystallography have resulted in EngA structures in different crystal forms. Although all the obtained structures represent the GDP-bound state, packing analysis has revealed conserved crystal contacts that can potentially stabilise this conformation during nucleation. Specific mutations aiming at disrupting these contacts may help to promote crystallisation of alternative conformations. Cryo-EM investigation has been initiated in order to obtain the structure of the B. subtilis EngA:50S complex. So far, an electron density map at 6.4 Å resolution has been obtained and its interpretation is underway.
Au cours des dernières années, le développement de nouvelles thérapies contre les infections bactériennes a suscité un grand intérêt face à l’émergence des nombreuses souches résistantes aux antibiotiques. Le point de départ de cette recherche de nouveaux antibiotiques, pour lesquels les bactéries n’ont pas encore acquis de mécanismes de résistance, est l’identification de nouvelles cibles cellulaires. En 2000, des études génétiques ont identifié engA, un gène bactérien dont le produit est une GTPase, comme une cible pharmacologique pertinente: elle est essentielle à la survie cellulaire, conservée au sein des bactéries et absente chez les eucaryotes.Puisque EngA agit comme un facteur d’assemblage pour le ribosome bactérien, un de nos objectifs a été de développer un test de criblage pour identifier des inhibiteurs des interactions EngA-ribosome. Ces interactions sont modulées par des changements conformationnels d'EngA, qui sont eux-mêmes déclenchés par la fixation de différents nucléotides dans le domaine catalytique. Cependant, les liens entre ces différents changements restent encore méconnus. Nous avons utilisé une approche multi-technique pour étudier ces questions et obtenir des informations utiles pour l’optimisation de notre test de criblage.Des analyses de SAXS et protéolyse limitée ont démontré un changement conformationnel en solution après adition de nucléotides di- ou tri-phosphate. La comparaison des données avec des modèles cristallographiques d'EngA a confirmé la conformation de la protéine liée au GDP. Cependant, la conformation de la protéine liée au GTP ne correspond à aucune structure connue. Des essais d’interaction ont démontré que la fixation de différents nucléotides au niveau des domaines catalytiques régule l’interaction d'EngA avec le ribosome. En outre, les effets des nucléotides se produisent en utilisant des fortes concentrations, ce qui suggère que le rôle d'EngA dans la biogenèse du ribosome peut être contrôlé par la concentration intracellulaire de nucléotides. Les travaux visant la détermination de la structure d'EngA dans sa conformation liée au GTP par cristallographie nous ont permis d’obtenir la structure d’EngA dans différentes formes cristallines. Cependant, ces structures représentent la conformation liée au GDP. L’analyse de l’empilement des cristaux a montré des contacts intermoléculaires conservés qui peuvent stabiliser cette conformation pendant la nucléation. Des mutations spécifiques permettant la rupture de ces contacts peuvent éventuellement aider à promouvoir la cristallisation de conformations alternatives. Des analyses de cryo-microscopie électronique ont débuté afin d’obtenir la structure du complexe EngA:50S de chez B. subtilis. Des résultats préliminaires montrent une carte de densité électronique à 6.4 Å de résolution. L’interprétation de ces résultats est en cours.
DASILVEIRATOME_2016_archivage.pdf (8.48 Mo) Télécharger le fichier
tel-01656732 , version 1 (06-12-2017)
  • HAL Id : tel-01656732 , version 1
Catarina da Silveira Tomé. Understanding ribosome binding interactions and conformational changes of the EngA bacterial GTPase, a potential target for new antibiotics. Structural Biology [q-bio.BM]. Université Grenoble Alpes, 2016. English. ⟨NNT : 2016GREAY033⟩. ⟨tel-01656732⟩
317 Consultations
359 Téléchargements
