Cytokines and growth factors cross-link heparan sulfate - Groupe Structure et Activité des Glycosaminoglycanes / Structure and Activity of Glycosaminoglycans Group (IBS-SAGAG) Accéder directement au contenu
Article Dans Une Revue Open Biology Année : 2015
The glycosaminoglycan heparan sulfate (HS), present at the surface of most cells and ubiquitous in extracellular matrix, binds many soluble extracellular signalling molecules such as chemokines and growth factors, and regulates their transport and effector functions. It is, however, unknown whether upon binding HS these proteins can affect the long-range structure of HS. To test this idea, we interrogated a supramolecular model system, in which HS chains grafted to streptavidin-functionalized oligoethylene glycol monolayers or supported lipid bilayers mimic the HS-rich pericellular or extracellular matrix, with the biophysical techniques quartz crystal microbalance (QCM-D) and fluorescence recovery after photobleaching (FRAP). We were able to control and characterize the supramolecular presentation of HS chains—their local density, orientation, conformation and lateral mobility—and their interaction with proteins. The chemokine CXCL12α (or SDF-1α) rigidified the HS film, and this effect was due to protein-mediated cross-linking of HS chains. Complementary measurements with CXCL12α mutants and the CXCL12γ isoform provided insight into the molecular mechanism underlying cross-linking. Fibroblast growth factor 2 (FGF-2), which has three HS binding sites, was also found to cross-link HS, but FGF-9, which has just one binding site, did not. Based on these data, we propose that the ability to cross-link HS is a generic feature of many cytokines and growth factors, which depends on the architecture of their HS binding sites. The ability to change matrix organization and physico-chemical properties (e.g. permeability and rigidification) implies that the functions of cytokines and growth factors may not simply be confined to the activation of cognate cellular receptors.
HS-crosslink-ms.pdf (1.67 Mo) Télécharger le fichier
hal-01184253 , version 1 (24-11-2020)
Elisa Migliorini, Dhruv Thakar, Jens Kühnle, Rabia Sadir, Douglas P. Dyer, et al.. Cytokines and growth factors cross-link heparan sulfate. Open Biology, 2015, 5, pp.150046. ⟨10.1098/rsob.150046⟩. ⟨hal-01184253⟩
279 Consultations
30 Téléchargements
