Characterisation of semaphorin 3A-chondroitin sulphate interaction in the central nervous system - Groupe Structure et Activité des Glycosaminoglycanes / Structure and Activity of Glycosaminoglycans Group (IBS-SAGAG) Accéder directement au contenu
Thèse Année : 2018
Caractérisation de l'interaction semaphorine 3A-chondroïtine sulfate dans le système nerveux central
Perineuronal nets (PNNs) are the key regulators of neuronal plasticity and regeneration in the mature central nervous system (CNS). They are a unique and highly organised extracellular matrix (ECM) structure, found around sub-population of neurons, composed mainly of chondroitin sulfate proteoglycan (CSPG). Chondroitin sulfate (CS) is a linear polysaccharide belonging to glycosaminoglycans (GAGs) family. The sulphation pattern defines different types of CS, which interact with different signalling proteins including those regulating axonal outgrowth and guidance such as semaphorin 3A (Sema3A). Sema3A is a secreted chemorepulsive protein found accumulated in the PNNs through its interaction with CS. This process is believed to potentiate Sema3A signalling through plexin A1 (PlxnA1) and Neuropilin 1 (Nrp1) and regulate plasticity and regeneration. The aim of the thesis project is to characterise the interface of Sema3A- CS interaction.For this purpose, Sema3A is expressed in eukaryote cells and purified. Interestingly, two major forms were obtained: a full length Sema3A (90 kDa) which remains attached to the cell surface GAGs and a truncated form without the C-ter part (65 kDa) which is released to the culture medium. With the use of surface plasmon resonance (SPR), we observed that full length Sema3A binds selectively to CS-E (4,6-disulfated chondroitin) and heparan sulfate with a high affinity (KD in the sub pM range), while the truncated Sema3A does not bind to any GAG. Four putative GAG binding sequences were identified in the C-ter of Sema3A and mutated using site directed mutagenesis. SPR analysis then revealed that two out of these four sites are required for the binding to CS-E. The importance of these GAG-binding sequences in inhibition of neurites outgrowth of dorsal root ganglion neurons in culture was also reported, indicating thus the importance of GAG-binding in Sema3A signalling. In parallel, the minimal required sequence of Sema3A-binding of CS-E was determined as being a tetrasaccharide. The Sema3A-CS interface was thus characterized. Furthermore, quartz crystal microbalance with dissipation monitoring analysis suggested that Sema3A could crosslink GAG chains. This suggests Sema3A could be involved in stabilising the PNN network and induces mechanical changes on neuronal surface.The detail characterization of Sema3A-CS interaction may enable the design of new strategies aiming at enhancing plasticity and regeneration for neurodegenerative diseases or spinal cord injury.
Les réseaux périneuronaux (PNN) sont des régulateurs clé de la plasticité et de la régénération des neurones au niveau du système nerveux central chez l’adulte. Le PNN est une matrice extracellulaire hautement organisée, qui entoure des populations spécifiques de neurones, enrichie en protéoglycanes à chondroïtine sulfate (CSPG). La chondroïtine sulfate (CS) est un polysaccharide linéaire, appartenant à la famille des glycosaminoglycanes (GAG), qui peut être sulfaté à différentes positions et donner lieu à plusieurs isoformes. Ces isoformes interagissent de manière spécifique avec de nombreuses molécules de signalisation dont la semaphorine 3A (Sema3A). Sema3A est une protéine secrétée, qui interagit avec les CS et s’accumule ainsi dans les PNN. Elle est impliquée dans la guidance des neurones sur lesquels elle agit par chemorepulsion. Les aspects structuraux et fonctionnels de l’ interaction entre Sema3A et CS sont encore mal connus, mais celle-ci pourrait être requise pour renforcer la liaison de la Sema3A avec ses récepteurs et déclencher une voie de signalisation qui aboutit à l’inhibition de la plasticité synaptique. Le but du projet est donc de caractériser biochimiquement l’interface d’interaction Sema3A-CS. Il a pour perspective d’élaborer des molécules interférant avec cette interaction qui pourraient permettre une amélioration de la plasticité neuronale après une maladie neurodégénérative ou une lésion de la moelle épinière.Pour ce faire, la Sema3A est exprimée dans un système hétérologue de cellules eucaryotes pour être purifiée. Deux formes ont été purifiées: une forme complète de 90 kDa qui reste accrochée à la surface cellulaire et une forme clivée de 65 kDa secrétée dans le milieu de culture. La Sema3A-90 interagit d’une manière sélective et avec une très haute affinité avec la CS-E (chondroitine disulfatée en position 4 et 6) et l’héparane sulfate,alors que, la forme clivée n’interagit avec aucun GAG, comme observé par résonance plasmonique de surface (SPR). Quatre sites, situés dans le domaine C-terminal de la protéine, susceptibles d’interagir avec les GAG ont été identifiés et analysés par mutagenèse. Deux d’entre eux sont impliqués dans la reconnaissance des GAG et sont nécessaires à la Sema3A pour inhiber la croissance de neurites sur des cultures de neurones issus de ganglion de la racine dorsale de rats. En parallèle, nos travaux montrent qu’un tetrasaccharide de CS-E est la taille minimale requise pour l’interaction avec la Sema 3A. Enfin, des analyses réalisées en utilisant une microbalance à cristal de quartz avec dissipation ont montré que la Sema3A pourrait réticuler les chaines de GAGs, participant ainsi à la stabilisation du réseau périneuronal.
DJERBAL_2018_archivage.pdf (8.06 Mo) Télécharger le fichier
tel-02144589 , version 1 (31-05-2019)
tel-02144589 , version 2 (04-06-2019)
  • HAL Id : tel-02144589 , version 2
Lynda Djerbal. Characterisation of semaphorin 3A-chondroitin sulphate interaction in the central nervous system. Biochemistry, Molecular Biology. Université Grenoble Alpes, 2018. English. ⟨NNT : 2018GREAV041⟩. ⟨tel-02144589v2⟩
411 Consultations
430 Téléchargements
