Some applications of compressed sensing in computational mechanics: model order reduction, manifold learning, data-driven applications and nonlinear dimensionality reduction - Institut de calcul intensif Accéder directement au contenu
Article Dans Une Revue Computational Mechanics Année : 2019
Compressed sensing is a signal compression technique with very remarkable properties. Among them, maybe the most salient one is its ability of overcoming the Shannon–Nyquist sampling theorem. In other words, it is able to reconstruct a signal at less than 2Q samplings per second, where Q stands for the highest frequency content of the signal. This property has, however, important applications in the field of computational mechanics, as we analyze in this paper. We consider a wide variety of applications, such as model order reduction, manifold learning, data-driven applications and nonlinear dimensionality reduction. Examples are provided for all of them that show the potentialities of compressed sensing in terms of CPU savings in the field of computational mechanics.
Matériaux
PIMM_CM_2019_IBANEZ.pdf (1.77 Mo) Télécharger le fichier
hal-02410086 , version 1 (13-12-2019)
R. Ibañez, Emmanuelle Abisset-Chavanne, Elías G. Cueto, Amine Ammar, Jean Louis Duval, et al.. Some applications of compressed sensing in computational mechanics: model order reduction, manifold learning, data-driven applications and nonlinear dimensionality reduction. Computational Mechanics, 2019, 64 (5), pp.1259-1271. ⟨10.1007/s00466-019-01703-5⟩. ⟨hal-02410086⟩
66 Consultations
364 Téléchargements
