Reshaping diagrams for bending straightening of forged aeronautical components - Institut de calcul intensif Accéder directement au contenu
Article Dans Une Revue International Journal of Advanced Manufacturing Technology Année : 2020
Large and thick-walled aluminium forgings exhibit shape distortions induced by residual stresses. To restore the nominal geometry, a series of highly-manual and time-consuming reshaping operations need to be carried out. In this paper, we are concerned with the development of efficient computer simulation tools to assist operators in bending straightening, which is one of the most common reshaping operations. Our approach is based on the computation of reshaping diagrams , a tool that allows selecting a nearly optimal bending load to be applied in order to minimize distortion. Most importantly, we show that the reshaping diagram needs not to account for the residual stress field, as its only effect is to shift of the reshaping di-This project has received funding from the European Union's Horizon 2020 research and innovation programme under the Marie Sk lodowska-Curie grant agreement No 675919. agram by some offset. That is, the overall behaviour including a realistic 3D residual stress field in a forged part can be retrieved by shifting the residual stress free reshaping diagram by the appropriate offset. Finally, we propose a strategy in order to identify the offset on-the-fly during the reshaping operation using simple force-displacement measures.
RM-MAGH-JAMT.pdf (8.13 Mo) Télécharger le fichier
hal-02910327 , version 1 (01-08-2020)
  • HAL Id : hal-02910327 , version 1
Ramiro Mena, Jose Vicente Aguado, Stéphane Guinard, Antonio Huerta. Reshaping diagrams for bending straightening of forged aeronautical components. International Journal of Advanced Manufacturing Technology, In press. ⟨hal-02910327⟩
78 Consultations
82 Téléchargements
