Publications of the AUTomatic control (AUT) team of IETR
The team is located on the Rennes campus of CentraleSupélec.
Quick links:
Latest Additions
Chargement de la page
Search
Full Text Publications
62
Bibliographic Records
251
Keywords
Type 1 diabetes Commande automatique Hybrid systems Compensating for disturbances Glycemia Adaptive estimation Commande prédictive Bipedal gait Closed Loop Control Cardiac resynchronization therapy Switched systems Optimization Intelligent Transportation Systems Diabetes Buildings Commande et optimisation des systèmes linéaires Biomedical Systems Adaptive Cruise Control Complex System Commande Prédictive ADMM Building Energy Management Systems Voltage stability AMDEC Closed-loop Control Analyse de stabilité Atteignabilité Tumor Growth Modeling Reactive power Adjoint model String stability Automation Biomedical model simulation Electric power systems Closed loop Energy storage Inverted pendulum Alimentation électrique Commande Prédictive Hiérarchisée Automotive vehicle dynamics System engineering Biomedical systems modeling Alimentation en énergie Close Loop Control System Engineering Extended Kalman Filter Arbres de Défaillances Bond-graph Least squares Commande distribuée Closed-loop control Modélisation Capteurs Parameter Estimation Adaptive FIR filter Automates programmables industriels Large scale optimization problems Identification Battery Closed-loop glucose control LMI Safety Maximum likelihood Robust control Building Energy Management System Computational modeling Sensor-augmented pump therapy A globally convergent estimator Boucle fermée Commutation cells Bio-procédés et science du vivant Analyse formelle Commande Hybride Maximum Likelihood Aiming Commande par mode glissant EIA-632 Systèmes hybrides Appareils de mesure électriques Artificial Pancreas Requirements Differentiator Appareils et matériel de commande automatique Tumor growth modeling Parameter estimation Comparative studies Bâtiment Energy management Complex Systems Velocity estimation Building control Channel estimation Bâtiments Stabilization Nonlinear systems Artificial pancreas Nonlinear Systems Adaptive control Bond graph Model predictive control
