Emerging Trends in Technological Innovation First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems, DoCEIS 2010, Costa de Caparica, Portugal, February 22-24, 2010
Conference papers
Characteristics of the PTC Heater Used in
Automotive HVAC Systems
Abstract : The present heating method which uses the cooling
system of the internal combustion engine of the vehicle takes a lot of
time to heat the interior air. In order to improve the heating process,
auxiliary devices are required. The new innovative techniques propose as
auxiliary heating device positive temperature coefficient heaters. For a
better control of the temperature, the parameters of these devices
should be known. This paper deals with a detailed description of the new
types of positive temperature coefficient heaters used in automotive
field. The test bench system developed for determining the parameters
and characteristics of the positive temperature coefficient heater is
described. The obtained data of the thermal resistance and
voltage-current characteristics are used for controlling the temperature
in order to design and control the positive temperature coefficient
heaters properly.
https://hal.inria.fr/hal-01060771
Contributor : Hal Ifip <>
Submitted on : Thursday, November 16, 2017 - 11:16:04 AM Last modification on : Wednesday, November 29, 2017 - 12:01:44 PM Long-term archiving on: : Saturday, February 17, 2018 - 4:10:50 PM
Radu Musat, Elena Helerea. Characteristics of the PTC Heater Used in
Automotive HVAC Systems. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.459-466, ⟨10.1007/978-3-642-11628-5_51⟩. ⟨hal-01060771⟩
