Conference papers
Disc Motor: Conventional and Superconductor Simulated Results Analysis
Abstract : Taking into consideration the development and integration of electrical machines with lower dimensions and higher performance, this paper presents the design and development of a three-phase axial flux disc motor, with 50 Hz frequency supply. It is made with two conventional semi-stators and a rotor, which can be implemented with a conventional aluminum disc or a high temperature-superconducting disc. The analysis of the motor characteristics is done with a 2D commercial finite elements package, being the modeling performed as a linear motor. The obtained results allow concluding that the superconductor motor provides a higher force than the conventional one. The conventional disc motor presents an asynchronous behavior, like a conventional induction motor, while the superconductor motor presents both synchronous and asynchronous behaviors.
Document type :
Conference papers
Complete list of metadatas
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01060776
Contributor : Hal Ifip <>
Submitted on : Thursday, November 23, 2017 - 4:24:09 PM
Last modification on : Tuesday, July 9, 2019 - 2:48:02 PM
File
InacioMNAR10.pdf
Identifiers
Citation
David Inácio, João Martins, Mário Ventim Neves, Alfredo Álvarez, Amadeu Leão Rodrigues. Disc Motor: Conventional and Superconductor Simulated Results Analysis. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.503-510, ⟨10.1007/978-3-642-11628-5_56⟩. ⟨hal-01060776⟩
Share
Metrics
Record views
221
Files downloads
196
