Emerging Trends in Technological Innovation First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems, DoCEIS 2010, Costa de Caparica, Portugal, February 22-24, 2010
Conference papers
Representing User Privileges in Object-Oriented
Virtual Reality Systems
Abstract : In virtual reality systems which are collaborative
and dynamic, i.e. where at run-time mutually interactive objects can be
added or removed in different contexts and where their behavior can be
modified, the problem of data security and privacy protection is
renewed. In such virtual worlds operations on objects should or should
not be allowed to users playing particular roles with respect to
inter-object interactions. In this paper a method called VR-PR is
presented, where privileges are represented by pairs: object - semantic
operations induced from object interactions. Semantic operations are
generated using automatic analysis of the object method call graphs.
Then they are used in the privilege creation and modification process.
Privileges based on semantic operations are expressive, flexible and
consistent with permanently evolving set of objects composing the
virtual world, interactions between the objects, and a set of
users.
https://hal.inria.fr/hal-01060788
Contributor : Hal Ifip <>
Submitted on : Friday, November 24, 2017 - 3:09:39 PM Last modification on : Tuesday, November 28, 2017 - 1:51:19 PM
Adam Wójtowicz, Wojciech Cellary. Representing User Privileges in Object-Oriented
Virtual Reality Systems. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.51-60, ⟨10.1007/978-3-642-11628-5_6⟩. ⟨hal-01060788⟩
