Conference papers
Self-adaptive Vision System
Abstract : Light conditions represent an important part of every vision application. This paper describes one active behavioral scheme of one particular active vision system. This behavioral scheme enables an active system to adapt to current environmental conditions by constantly validating the amount of the reflected light using luminance meter and dynamically changed significant vision parameters. The purpose of the experiment was to determine the connections between light conditions and inner vision parameters. As a part of the experiment, Response Surface Methodology (RSM) was used to predict values of vision parameters with respect to luminance input values. RSM was used to approximate an unknown function for which only few values were computed. The main output validation system parameter is called Match Score. Match Score indicates how well the found object matches the learned model. All obtained data are stored in the local database. By timely applying new parameters predicted by the RSM, the vision application works in a stabile and robust manner.
Document type :
Conference papers
Complete list of metadatas
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01060803
Contributor : Hal Ifip <>
Submitted on : Friday, November 17, 2017 - 3:15:10 PM
Last modification on : Wednesday, November 29, 2017 - 10:53:41 AM
Long-term archiving on: : Sunday, February 18, 2018 - 2:53:41 PM
File
StipancicJ10.pdf
Identifiers
Citation
Tomislav Stipancic, Bojan Jerbic. Self-adaptive Vision System. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.193-200, ⟨10.1007/978-3-642-11628-5_21⟩. ⟨hal-01060803⟩
Share
Metrics
Record views
169
Files downloads
153
