Conference papers
Collaborating and Learning Predators on a Pursuit Scenario
Abstract : A generic predator/prey pursuit scenario is used to validate a common learning approach using Wilson's eXtended Learning Classifier System (XCS). The predators, having only local information, should independently learn and act while at the same time they are urged to collaborate and to capture the prey. Since learning from scratch is often a time consuming process, the common learning approach, as investigated here, is compared to an individual learning approach of selfish learning agents. A special focus is set on the performance of how quickly the team goal is achieved in both learning scenarios. This paper provides new insights of how agents with local information could learn collaboratively in a dynamically changing multi-agent environment. Furthermore, the concept of a common rule base based on Wilson's XCS is investigated. The results based on the common rule base approach show a significant speed up in the learning performance but may be significantly inferior on the long run, in particular in situations with a moving prey.
Document type :
Conference papers
Complete list of metadatas
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01054491
Contributor : Hal Ifip <>
Submitted on : Thursday, August 7, 2014 - 11:02:46 AM
Last modification on : Thursday, March 5, 2020 - 5:40:45 PM
Long-term archiving on: : Wednesday, November 26, 2014 - 1:21:14 AM
File
final_07.pdf
Identifiers
Citation
Nugroho Fredivianus, Urban Richter, Hartmut Schmeck. Collaborating and Learning Predators on a Pursuit Scenario. 7th IFIP TC 10 Working Conference on Distributed, Parallel and Biologically Inspired Systems (DIPES) / 3rd IFIP TC 10 International Conference on Biologically-Inspired Collaborative Computing (BICC) / Held as Part of World Computer Congress (WCC) , Sep 2010, Brisbane, Australia. pp.290-301, ⟨10.1007/978-3-642-15234-4_28⟩. ⟨hal-01054491⟩
Share
Metrics
Record views
413
Files downloads
528
