HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Full Text Documents
79
Search
Table of Contents
Advances in Production Management Systems, New Challenges, New Approaches
Bruno Vallespir, Thècle Alix
Front Matter
Part I: Production Systems
Production Processes
Integration of Supplier and Customer's Production Processes
Marek Eisler, Remigiusz Horbal
3-10
Methodology of Designing Disassembly and Reassembly Processes Using Lean Thinking Approach
Tomasz Kanikuła, Tomasz Koch
11-18
Evaluating Energy Efficiency Improvements in Manufacturing Processes
Katharina Bunse, Julia Sachs, Matthias Vodicka
19-26
Integrated Micro Process Chains
Bernd Scholz-Reiter, Nele Brenner, Alice Kirchheim
27-32
Improvement Tools for NEH Based Heuristics on Permutation and Blocking Flow Shop Scheduling Problems
Ramon Companys, Imma Ribas, Manel Mateo
33-40
A Basic Study on the Installation of Distributed Autonomous Production Scheduling System in Ubiquitous Environment
Susumu Fujii, Tomomitsu Motohashi, Takashi Irohara, Yuichiro Miyamoto
41-48
Experimental Evaluation of Inventory-Based Discrete-Updating Market Maker for Intra-firm Prediction Market System Using VIPS
Hajime Mizuyama, Morio Ueda, Katsunobu Asada, Yu Tagaya
49-56
Database Scheme Configuration for a Product Line of MPC-TOOLS
Benjamin Klöpper, Tobias Rust, Bernhard Vedder, Wilhelm Dangelmaier
57-64
Production Systems Design
Balancing Mass Production Machining Lines with Genetic Algorithms
Olga Guschinskaya, Evgeny Gurevsky, Anton Eremeev, Alexandre Dolgui
65-72
A Top-Down Approach for an Automatic Precedence Graph Construction under the Influence of High Product Variety
Simon Altemeier, Daniel Brodkorb, Wilhelm Dangelmaier
73-80
Lean Management
A Conceptual Model for Production Leveling (Heijunka) Implementation in Batch Production Systems
Luciano Fonseca De Araujo, Abelardo Alves De Queiroz
81-88
The Moderating Role of JIT Links with Suppliers on the Relationship between Lean Manufacturing and Operational Performances
Pietro Romano, Pamela Danese, Thomas Bortolotti
89-96
Type Toyota Management Systems (MSTT) of Small and Medium-Sized Enterprises in Mechanical and Electrical Industry
Stefan Kluge, Andreas Rau, Engelbert Westkämper
97-104
Production Leveling (Heijunka) Implementation in a Batch Production System: A Case Study
Luciano Fonseca Araujo, Abelardo Alves Queiroz
105-112
Maintenance, Inspection and Monitoring
Towards a Maintenance and Servicing Indicator
Pascal Vrignat, Manuel Avila, Florent Duculty, Frédéric Kratz
113-120
Monitoring of Collaborative Assembly Operations: An OEE Based Approach
Sauli Kivikunnas, Esa-Matti Sarjanoja, Jukka Koskinen, Tapio Heikkilä
121-127
The Value of Sampling Inspection in a Single-Period Remanufacturing System with Stochastic Returns Yield
Christos Zikopoulos, Sofia Panagiotidou, George Nenes
128-135
Risks and Uncertainty
The Impact of Behavior-Based Strategies on Supply Uncertainty
Pirola Fabiana, Pinto Roberto
136-143
MRP Offsetting for Assembly Systems with Random Component Delivery Times: A Particular Case
Mohamed-Aly Louly, Alexandre Dolgui
144-151
Sustainability
From Product End-of-Life Sustainable Considerations to Design Management
Natalia Duque Ciceri, Marco Garetti, Severine Sperandio
152-159
A Conceptual Framework for Sustainable Manufacturing by Focusing on Risks in Supply Chains
Masaru Nakano
160-167
Introducing Energy Performances in Production Management: Towards Energy Efficient Manufacturing
Alessandro Cannata, Marco Taisch
168-175
Part II: Supply Chains
Supply Chains Operation Management
Supply Chain Reactivity Assessment Regarding Two Negotiated Commitments: Frozen Horizon and Flexibility Rate
Aïcha Amrani-Zouggar, Jean-Christophe Deschamps, Jean-Paul Bourrières
179-186
Principles for Real-Time, Integrated Supply Chain Control: An Example from Distribution of Pharmaceuticals
Heidi C. Dreyer, Jan Ola Strandhagen, Anita Romsdal, Annette Hoff
187-194
Capacity Adjustment through Contingent Staffing Outsourcing
Gilles Neubert, Philippe Adjadj
195-202
Coordination in Supply Chains: From Case Studies to Reference Models
Yue Ming, Raymond Houé, Bernard Grabot
203-210
Production Networks
Construction Logistics Improvements Using the SCOR Model - Tornet Case
Fredrik Persson, Jonas Bengtsson, Örjan Gustad
211-218
Interoperability Constraints and Requirements Formal Modelling and Checking Framework
Vincent Chapurlat, Matthieu Roque
219-226
Cooperative Supply Chains: Models and Challenges
A Study on VMI-Based Supply-Chain System by Simulation Analysis
Shigeki Umeda
227-234
How do the Key Determinants of a Distributed Planning Process Impact on the Performance of a Supply Chain?
Julien François, Uche Okongwu, Jean-Christophe Deschamps, Matthieu Lauras
235-242
The Application of Lean Production Control Methods within a Process-Type Industry: The Case of Hydro Automotive Structures
Daryl Powell, Erlend Alfnes, Marco Semini
243-250
A Data Aggregation Methodology to Assess the Global Production Capacity of Complex Supply Chains
Frederic Pereyrol, Jean-Christophe Deschamps, Julien François, Pascale Farthouat, Remy Dupas
251-258
Relationships with Suppliers
The Behavior of Suppliers in Supplier-Customer Relationships
Ralph Riedel, Norbert Neumann, Marco Franke, Egon Müller
259-266
Multi-supplier Systems with Seasonal Demand
Ekaterina Bulinskaya, Larisa Afanasyeva
267-274
Relationships with Customers
A Concurrent Newsvendor Problem with Rationing
Pinto Roberto
275-282
A Model for Vendor Selection and Dynamic Evaluation
Raffele Iannone, Salvatore Miranda, Stefano Riemma, Debora Sarno
283-290
Customer Driven Capacity Setting
Alexander Hübl, Klaus Altendorfer, Herbert Jodlbauer, Josef Pilstl
291-298
New Practices in Transportation and Logistic Organisations
Decision Making Tool for the Selection of Urban Freight Transport Project
Nicolas Malhéné, Dominique Breuil
299-306
Making PROFIT at the Intermodal Terminal - A Research Agenda
Torbjörn H. Netland, Ingrid Spjelkavik
307-314
The Value of Lead Logistics Services
Oliver Schneider, André Lindner
315-322
Part III: Interoperable and Distributed Systems
Interoperable and Agile Production Systems
High Resolution Supply Chain Management - Resolution of the Polylemma of Production by Information Transparency and Organizational Integration
Tobias Brosze, Fabian Bauhoff, Volker Stich
325-332
Superior Performance of Leagile Supply Networks by Application of Autonomous Control
Bernd Scholz-Reiter, Afshin Mehrsai
333-341
Analysis of the Harmonizing Potential of Order Processing Attributes in Spread Production Systems
Dirk Oedekoven, Volker Stich, Tobias Brosze, Stefan Cuber
342-349
Agent Modelling, Distributed Simulation and Control Frameworks for Production Management Systems
HLA Multi Agent/Short-Lived Ontology Platform for Enterprise Interoperability
Gregory Zacharewicz, Olivier Labarthe, David Chen, Bruno Vallespir
350-357
Model Based on Bayesian Networks for Monitoring Events in a Supply Chain
Erica Fernández, Enrique Salomone, Omar Chiotti
358-365
Simulation Model Driven Engineering for Manufacturing Cell
Hironori Hibino, Toshihiro Inukai, Yukishige Yoshida
366-373
VirtES (Virtual Enterprise Simulator): A Proposed Methodology for Enterprise Simulation Modeling
Giovanni Davoli, Sergio A. Gallo, Riccardo Melloni
374-380
Part IV: Strategy and Innovation
Change, Strategy and Innovation
Measuring the Intangible Aspects of the Manufacturing Strategy - A Case Study from the Automotive Industry
Bjørnar Henriksen, Lars E. Onsøyen
383-391
Managing Innovation: A Multidisciplinary Scenario Development Approach
Esmond Urwin, Michael Henshaw
392-399
Projects and Life Cycle
Industrialization and Manufacturing Steps within the Global Product Lifecycle Context
Anis Ben Khedher, Sébastien Henry, Abelaziz Bouras
400-408
Analysis of End-of-Life Vehicle Processes: A Case Study in Sardinia (Italy)
Carlo Enrico Carcangiu, Pier Francesco Orrù, Maria Teresa Pilloni
409-416
Increasing Project Control and Guidance through a Time-frame Simulation Approach
Massimo Falco, Luisa Falivene
417-424
Advanced Topics in Project Management Process
Lucio Bianco, Massimiliano Caramia
425-432
Knowledge Management
Knowledge Based Enterprise Engineering (KBEE): A Modeling Framework for Enterprise Knowledge Capitalization
Mahmoud Moradi, Mounir Badja, Bruno Vallespir
433-440
The Knowledge Dimension of Production Transfer
Jens O. Riis, Brian Vejrum Waehrens, Erik Skov Madsen
441-448
Information and Communication Technologies
A Framework for Enhancing Responsiveness in Sales Order Processing System Using Web Services and Ubiquitous Computing Technologies
Mokmin Park, Kitae Shin, Hanil Jeong, Jinwoo Park
449-456
How to Foresee and Capture the Effects of RFID Implementation
Kristin Hergot, Lars Skjelstad
457-464
Co-evolution of Product Design and Supply Chain Considering Change Management Strategies
Network Compatibility Blocs as Basis of Partner's Selection
Salah Zouggar, Marc Zolghadri, Xin Zhang, Philippe Girard
465-472
Knowledge Based Product and Process Engineering Enabling Design and Manufacture Integration
Matthieu Bricogne, Farouk Belkadi, Magali Bosch-Mauchand, Benoît Eynard
473-480
Part V: Performances
Performance Measurement and Costing
Proposal of a Performance Measurement System for Professional Non-profit Service Organizations
Michela Benedetti, Sergio Terzi
483-490
Total Cost of Ownership Considerations in Global Sourcing Processes
Robert Alard, Philipp Bremen, Josef Oehmen, Christian Schneider
491-498
Designing and Implementing a Framework for Process-Oriented Logistics-Costs Measurement in an Automotive-Supplier Group
Gregor Von Cieminski, Michael Karrer, Malte Zur
499-505
Quality
Analysis of Quality in Brazilian E-Commerce (B2C)
Pedro Luiz Oliveira Costa Neto, José Paulo Alves Fusco, João Gilberto Mendes Dos Reis
506-513
Implementing Six Sigma in Challenging Times: A Case Study
Jose Hernandez, Trevor Turner
514-521
Development of Manufacture Support System Using Taguchi Methods
Ikuo Tanabe
522-529
From Single to Networked Enterprises Performance Measurement and Management
Integration of Requirements for Performance Indicator System Definition and Implementation Methods
Michel Ravelomanantsoa, Yves Ducq, Bruno Vallespir
530-537
Innovation Management in European Projects
Bernard Monnier, Marc Zolghadri
538-544
Understanding Process Quality in the Context of Collaborative Business Network Structures
Patrick Sitek, Novica Zarvić, Marcus Seifert, Klaus-Dieter Thoben
545-552
Part VI: Service
Services
The Concept of Modularisation of Industrial Services
Fabrice Seite, Oliver Schneider, Andreas Nobs
555-562
A Multi-dimensional Service Chain Ecosystem Model
Frédérique Biennier, Régis Aubry, Youakim Badr
563-570
Hypergraph of Services for Business Interconnectivity and Collaboration
Alida Esper, Youakim Badr, Frédérique Biennier
571-578
Lean First, Then Automate: An Integrated Model for Process Improvement in Pure Service-Providing Companies
Thomas Bortolotti, Pietro Romano, Bernardo Nicoletti
579-586
Implementing Lean into a Servicing Environment
Ross Ritchie, Jannis Angelis
587-594
Health Care Provider Processes Analysis
Lukasz Kawczynski, Marco Taisch
595-602
Networked Service Innovation Process in the Production of a New Urban Area
Erja Väyrynen, Riitta Smeds
603-610
Health Care Provider Value Chain
611-618
Business Process and Performance Management of Product-Service Systems
Contribution to the Definition and Modeling of Service and Service Activities
Mounir Badja, Wael Touzi, Thècle Alix
619-626
A Structured Comparison of the Service Offer and the Service Supply Chain of Manufacturers Competing in the Capital Goods and Durable Consumer Goods Industries
Donatella Corti, Alberto Portioli-Staudacher
627-635
Business Process Management Systems - Enabling Continuous Improvement in Industrial Services
Heikki Hirvensalo, Jan Holmström, Timo Ala-Risku
636-643
A Framework for Product-Service Design for Manufacturing Firms
Thècle Alix, Bruno Vallespir
644-651
Lean Implementation in Service Companies
652-659
Exploring the Causal Relationships of KPIs in after Sales Service Systems
Elena Legnani, Sergio Cavalieri
660-668
