Conference papers
A Tool for Automatic Creation of Rule-Based Expert Systems with CFs
Abstract : This paper introduces a tool, namely ACRES (Automatic CReator of Expert Systems), which can automatically produce rule-based expert systems as CLIPS scripts from a dataset containing knowledge about a problem domain in the form of a large number of cases. The rules are created via a simple systematic approach and make use of certainty factors (CFs). CFs of same conclusions can be combined either using the MYCIN method or a generalization of MYCIN's method. This latter method requires calculation of some weights, based on a training dataset, via the use of a genetic algorithm. Creation of an expert system is outlined. Small scale experimental results comparing the above methods with each other and a neural network are finally presented.
Document type :
Conference papers
Complete list of metadatas
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01060668
Contributor : Hal Ifip <>
Submitted on : Thursday, November 16, 2017 - 3:39:12 PM
Last modification on : Thursday, March 5, 2020 - 5:43:04 PM
Document(s) archivé(s) le : Saturday, February 17, 2018 - 2:46:00 PM
File
HatzilygeroudisK10.pdf
Identifiers
Citation
Ioannis Hatzilygeroudis, Konstantinos Kovas. A Tool for Automatic Creation of Rule-Based Expert Systems with CFs. 6th IFIP WG 12.5 International Conference on Artificial Intelligence Applications and Innovations (AIAI), Oct 2010, Larnaca, Cyprus. pp.195-202, ⟨10.1007/978-3-642-16239-8_27⟩. ⟨hal-01060668⟩
Share
Metrics
Record views
350
Files downloads
552
