Abstract : The location information is very crucial for the sensing data in modern agriculture. However, positioning errors and sparse anchors are two key problems that should first be solved for the localization of the sensor nodes. We proposed a novel algorithm to tackle with these challenges. When the system of adjacent anchor distance equations is ill, a minimized-stress search algorithm (MSS) can decrease positioning error greatly. A collaborative sparse-anchored scheme (CSA) has an excellent positioning effect on low density of anchor, specifically on marginal sensor nodes. Our experimental result verified validity and accuracy of the algorithm. It improved feasibility and cost of WSN positioning technique, significantly.
https://hal.inria.fr/hal-01559597
Contributor : Hal Ifip
Submitted on : Monday, July 10, 2017 - 5:28:22 PM
Last modification on : Tuesday, July 18, 2017 - 3:30:00 PM
Long-term archiving on: Wednesday, January 24, 2018 - 4:57:00 PM
Chunjiang Zhao, Shufeng Wang, Kaiyi Wang, Zhongqiang Liu, Feng Yang, et al.. A Localization Algorithm for Sparse-Anchored WSN in Agriculture. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.76-86, ⟨10.1007/978-3-642-18333-1_11⟩. ⟨hal-01559597⟩
