Conference papers
Study of Optimal Operation for Huai’an Parallel Pumping Stations with Adjustable-Blade Units Based on Two Stages Decomposition-Dynamic Programming Aggregation Method
Abstract : Two-stage decomposition-dynamic programming aggregation method has been first proposed and introduced to solve the mathematical model of daily optimal operation for parallel pumping stations with adjustable-blade units. Taking minimal daily electricity cost of single pump station as objective function, the water quantity pumped by each station as coordinated variable, by means of the type of the pump units this model is decomposed into several first-stage sub-model of daily optimal operation with adjustable-blade for single pump station. Then taking minimal daily electricity cost of single pump unit as objective function, the water quantity pumped by each unit as coordinated variable, the first-stage sub-model is decomposed into several second-stage sub-model of daily optimal operation with adjustable-blade for single pump unit which takes the blade angle as decision variable, the discrete values of water quantity pumped by each unit as state variable, and is solved by means of dynamic programming method. The constructed aggregation model takes daily water quantity pumped by each pump unit as decision variable, the discrete values of water quantity pumped by parallel station group as state variable, and is also solved by dynamic programming method. The aggregation process replaces the traditional method of constructing equations. This method has first solved the optimal operation issues for multi-units of parallel stations with various operation modes, time period division and daily average head of each station, and also provided theoretical support for the study on optimal operation of multi-stage pumping stations. Taking Huai’an No.1, No.2, and No.4 parallel pumping stations as a study case, a series of optimization results have been obtained.
Document type :
Conference papers
Complete list of metadatas
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01563407
Contributor : Hal Ifip <>
Submitted on : Monday, July 17, 2017 - 4:59:30 PM
Last modification on : Thursday, March 5, 2020 - 5:41:18 PM
Long-term archiving on: : Saturday, January 27, 2018 - 3:31:34 AM
File
978-3-642-18354-6_65_Chapter.p...
Identifiers
Citation
Yi Gong, Jilin Cheng, Rentian Zhang, Lihua Zhang. Study of Optimal Operation for Huai’an Parallel Pumping Stations with Adjustable-Blade Units Based on Two Stages Decomposition-Dynamic Programming Aggregation Method. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.554-562, ⟨10.1007/978-3-642-18354-6_65⟩. ⟨hal-01563407⟩
Share
Metrics
Record views
116
Files downloads
202
