Full Text Documents
Chargement de la page
Search
Table of Contents
Computer and Computing Technologies in Agriculture IV
Daoliang Li, Yande Liu, Yingyi Chen
Book Front Matter
A Compression Method of Decision Table Based on Matrix Computation
Laipeng Luo, Ergen Liu
1-7
A Laplacian of Gaussian-Based Approach for Spot Detection in Two-Dimensional Gel Electrophoresis Images
Feng He, Bangshu Xiong, Chengli Sun, Xiaobin Xia
8-15
A Leaf Layer Spectral Model for Estimating Protein Content of Wheat Grains
Chun-Hua Xiao, Shao-Kun Li, Ke-Ru Wang, Yan-Li Lu, Jun-Hua Bai, Rui-Zhi Xie, Shi-Ju Gao, Qiong Wang, Fang-Yong Wang
16-29
A New Color Information Entropy Retrieval Method for Pathological Cell Image
Xiangang Jiang, Qing Liang, Tao Shen
30-38
A New Palm-Print Image Feature Extraction Method Based on Wavelet Transform and Principal Component Analysis
Jia Li, Ming Sun
39-46
A Non-linear Model of Nondestructive Estimation of Anthocyanin Content in Grapevine Leaves with Visible/Red-Infrared Hyperspectral
Jianglin Qin, Donald Rundquist, Anatoly Gitelson, Zongkun Tan, Mark Steele
47-62
Application of Improved BP Neural Network in Controlling the Constant-Force Grinding Feed
Zhaoxia Chen, Bailin He, Xianfeng Xu
63-70
A Semantic Middleware of Grain Storage Internet
Siquan Hu, Haiou Wang, Chundong She, Junfeng Wang
71-77
AE Feature Analysis on Welding Crack Defects of HG70 Steel Used by Truck Crane
Yantao Dou, Xiaoli Xu, Wei Wang, Siqin Pang
78-88
An Equilateral Triangle Waveguide Beam Splitter
Zhimin Liu, Fengqi Zhou, Hongjian Li, Bin Tang, Zhengfang Liu, Qingping Wu, Aixi Chen, Kelin Huang
89-95
Analysis and Implementation of Embedded SNMP Agent
Hubin Deng, Guiyuan Liu, Lei Zhang
96-102
Application of Computer Technology in Advanced Material Science and Processing
Yajuan Liu
103-107
Application of Interferometry in Ultrasonic System for Vibration
Zhengping Liu, Shenghang Xu, Juanjuan Liu
108-115
Automatic Control System for Highway Tunnel Lighting
Shijuan Fan, Chao Yang, Zhiwei Wang
116-123
Comparative Study of Distance Discriminant Analysis and Bp Neural Network for Identification of Rapeseed Cultivars Using Visible/Near Infrared Spectra
Qiang Zou, Hui Fang, Fei Liu, Wenwen Kong, Yong He
124-133
Current Situation and Prospect of Grassland Management Decision Support Systems in China
Qingwei Duan, Xiaoping Xin, Guixia Yang, Baorui Chen, Hongbin Zhang, Yuchun Yan, Xu Wang, Baohui Zhang, Gang Li
134-146
Design Method and Implementation of Ternary Logic Optical Calculator
Chunzhi Li, Junyong Yan
147-166
Design of Automatic Cutting and Welding Machine for Brake Beam-Axle
Leping Liu, Mingdong Zhong, Qizheng Dong
167-176
Design of Multifunction Vehicle Bus Controller
Zhongqi Li, Fengping Yang, Qirong Xing
177-183
Detection of Soil Total Nitrogen by Vis-SWNIR Spectroscopy
Yaoze Feng, Xiaoyu Li, Wei Wang, Changju Liu
184-191
Development and Application of Tennis Match Video Retrieval Technology in Multimedia Education
Shehua Cao
192-197
Fault Diagnosis of Roller Bearing Based on PCA and Multi-class Support Vector Machine
Guifeng Jia, Shengfa Yuan, Chengwen Tang
198-205
Health Status Identification of Connecting Rod Bearing Based on Support Vector Machine
Yongbin Liu, Qingbo He, Ping Zhang, Zhongkui Zhu, Fanrang Kong
206-214
Investigation of the Methods for Tool Wear On-Line Monitoring during the Cutting Process
Hongjiang Chen
215-220
Magnetic-Field-Based 3D ETREE Modelling for Multi-Frequency Eddy Current Inspection
Yu Zhang, Yong Li
221-230
Measurement of Self-emitting Magnetic Signals from a Precut Notch of Q235 Steel during Tensile Test
Lihong Dong, Binshi Xu, Shiyun Dong
231-236
Modeling and Performance Analysis of Giant Magnetostrictive Microgripper with Flexure Hinge
Qinghua Cao, Quanguo Lu, Junmei Xi, Jianwu Yan, Changbao Chu
237-245
Non-destructive Measurement of Sugar Content in Chestnuts Using Near-Infrared Spectroscopy
Jie Liu, Xiaoyu Li, Peiwu Li, Wei Wang, Jun Zhang, Wei Zhou, Zhu Zhou
246-254
Nondestructive Testing Technology and Optimization of On-Service Urea Reactor
Xiaoling Luo, Lei Deng
255-259
Parameters Turning of the Active-Disturbance Rejection Controller Based on RBF Neural Network
Baifen Liu, Ying Gao
260-267
Research of Intelligent Gas Detecting System for Coal Mine
Chen Hui
268-278
Research of Subway’s Train Control System Based on TCN
Qingfeng Ding, Fengping Yang, Qixin Zhu
279-285
Shape Detection for Impeller Blades by Non-contact Coordinate Measuring Machine
Shimin Luo
286-293
Simulation of Road Surface Roughness Based on the Piecewise Fractal Function
Zhixiong Lu, Lanying Zhao, Xiaoqin Li, Jun Yuan
294-305
Stress Analysis Near the Welding Interface Edges of a QFP Structure under Thermal Loading
Zhigang Huang, Xuecheng Ping, Pingan Liu
306-313
Study of Intelligent Diagnosis System for Mechanism Wear Fault Based on Fuzzy-Neural Networks
Sanmao Xie
314-320
Study on Autonomous Path Planning by Mobile Robot for Road Nondestructive Testing Based on GPS
Lunhui Xu, Fan Ye, Yanguo Huang
321-332
Study on Imitating Grinding of Two-Dimensional Ultrasonic Vibration Turning System
Leping Liu, Wen Zhao, Yuan Ma
333-344
Study on Optimal Path Changing Tools in CNC Turret Typing Machine Based on Genetic Algorithm
Min Liu, Xiaoling Ding, Yinfa Yan, Xin Ci
345-354
Study on the Problem and Countermeasure of Fruit Production Quality and Safety in Yanshan Mountain
Haisheng Gao, Bin Du, Fengmei Zhu
355-360
Calculation and Analysis of Double-Axis Elliptical-Parabolic Compond Flexure Hinge
Ping’ Liu, Jianqun Cheng, Zhigang Lai
361-367
Surface Distresses Detection of Pavement Based on Digital Image Processing
Aiguo Ouyang, Chagen Luo, Chao Zhou
368-375
The Application Research of Neural Network in Embedded Intelligent Detection
Xiaodong Liu, Dongzhou Ning, Hubin Deng, Jinhua Wang
376-381
The Theoretical Analysis of Test Result’s Errors for the Roller Type Automobile Brake Tester
Jun Li, Xiaojing Zha, Dongsheng Wu
382-389
A Type of Arithmetic Labels about Circulating Ring
Ergen Liu, Dan Wu, Kewen Cai
390-397
Application of CPLD in Pulse Power for EDM
Yang Yang, Yanqing Zhao
398-402
Application of IDL and ENVI Redevelopment in Hyperspectral Image Preprocessing
Long Xue
403-409
Design of Integrated Error Compensating System for the Portable Flexible CMMs
Qing-Song Cao, Jie Zhu, Zhi-Fan Gao, Guo-Liang Xiong
410-419
Detecting and Analyzing System for the Vibration Comfort of Car Seats Based on LabVIEW
Ying Qiu
420-426
Determination of Pesticide Residues on the Surface of Fruits Using Micro-Raman Spectroscopy
Yande Liu, Tao Liu
427-434
Development of the Meter for Measuring Pork Quality Based on the Electrical Characteristics
Zhen Xing, Wengang Zheng, Changjun Shen, Xin Zhang
435-442
Experimental Investigation of Influence on Non-destructive Testing by Form of Eddy Current Sensor Probe
Fengyun Xie, Jihui Zhou
443-449
Feasibility of Coordinate Measuring System Based on Wire Driven Robot
Ji-Hui Zhou, Qing-Song Cao, Fa-Xiong Sun, Lan Bi
450-459
HSFDONES: A Self-Leaning Ontology-Based Fault Diagnosis Expert System Framework
Xiangbin Xu
460-466
Nondestructive Measurement of Sugar Content in Navel Orange Based on Vis-NIR Spectroscopy
Chunsheng Luo, Long Xue, Muhua Liu, Jing Li, Xiao Wang
467-473
Numerical Simulation of Temperature Field in Selective Laser Sintering
Jian Zhang, Deying Li, Jianyun Li, Longzhi Zhao
474-479
Numerical Simulations of Compression Properties of SiC/Al Co-continuous Composites
Mingjuan Zhao, Na Li, Longzhi Zhao, Xiaolan Zhang
480-485
Simulation and Optimization in Production Logistics Based on eM-Plant Platform
Xinjian Zhou, Xiangbin Xu, Wei Zhu
486-493
Simulation of Transient Temperature Field in the Selective Laser Sintering Process of W/Ni Powder Mixture
Jiwen Ren, Jianshu Liu, Jinju Yin
494-503
Study on Plant Nutrition Indicator Using Leaf Spectral Transmittance for Nitrogen Detection
Juanxiu Hu, Dongxian He, Po Yang
504-513
Study on the Influence of Non-electrical Parameters on Processing Quality of WEDM-HS and Improvement Measures
Guangyao Xiong, Meizhu Zheng, Deying Li, Longzhi Zhao, Yanlin Wang, Minghui Li
514-520
Test Analysis and Theoretical Calculation on Braking Distance of Automobile with ABS
Dongsheng Wu, Jun Li, Xiaoping Shu, Xiaojing Zha, Beili Xu
521-527
The Detection of Early-Maturing Pear’s Effective Acidity Based on Hyperspectral Imaging Technology
Pengbo Miao, Long Xue, Muhua Liu, Jing Li, Xiao Wang, Chunsheng Luo
528-536
The Effects of Internal and External Factors on the Mechanical Behavior of the Foam Copper
Longzhi Zhao, Xiaolan Zhang, Na Li, Mingjuan Zhao, Jian Zhang
537-542
Optimum Design of Runner System for Router Cover Based on Mold Flow Analysis Technology
Tangqing Kuang, Wenjuan Gu
543-554
Design of Tread Flange Injection Mold Based on Pro/E
Huilan Zhou
555-562
Study on the Online Control System to Prevent Drunk Driving Based on Photoelectric Detection Technology
Lu Liming, Yang Yuchuan, Lu Jinfu
563-567
The Design and Simulation of Electro-Hydraulic Velocity Control System
Fengtao Lin
568-574
Application of Background Information Database in Trend Change of Agricultural Land Area of Guangxi
Xin Yang, Shiquan Zhong, Yuhong Li, Weiping Lu, Chaohui Wu
575-582
Reasons of the Incremental Information in the Updating Spatial Database
Huaji Zhu, Huarui Wu, Xiang Sun
583-591
Research on Non-point Source Pollution Based on Spatial Information Technology: A Case Study in Qingdao
Tao Shen, Jinheng Zhang, Junqiang Wang
592-601
The Regulation Analysis of Low-Carbon Orientation for China Land Use
Bikai Gong, Bing Chen
602-609
A CDMA-Based Soil-Quality Monitoring System for Mineland Reclamation
Dongxian He, Daoliang Li, Jie Bao, Shaokun Lu
610-615
Design and Implementation of a Low-Power ZigBee Wireless Temperature Humidity Sensor Network
Shuipeng Gong, Changli Zhang, Lili Ma, Junlong Fang, Shuwen Wang
616-622
Land Evaluation Supported by MDS
Fengchang Xue
623-628
Design and Development of Water Quality Monitoring System Based on Wireless Sensor Network in Aquaculture
Mingfei Zhang, Daoliang Li, Lianzhi Wang, Daokun Ma, Qisheng Ding
629-641
Design of an Intelligent PH Sensor for Aquaculture Industry
Haijiang Tai, Qisheng Ding, Daoliang Li, Yaoguang Wei
642-649
A Simple Temperature Compensation Method for Turbidity Sensor
Haijiang Tai, Daoliang Li, Yaoguang Wei, Daokun Ma, Qisheng Ding
650-658
A Wireless Intelligent Valve Controller for Agriculture Integrated Irrigation System
Nannan Wen, Daoliang Li, Daokun Ma, Qisheng Ding
659-671
Evaluation of the Rural Informatization Level in Central China Based on Catastrophe Progression Method
Lingxian Zhang, Xue Liu, Zetian Fu, Daoliang Li
672-679
GIS-Based Evaluation on the Eco-Demonstration Construction in China
Lingxian Zhang, Juncheng Ma, Daoliang Li, Zetian Fu
680-690
Modeling and Analysis of Pollution-Free Agricultural Regulatory Based on Petri-Net
Fang Wang, Qingling Duan, Lingzi Zhang, Guo Li
691-700
An Online Image Segmentation Method for Foreign Fiber Detection in Lint
Daohong Kan, Daoliang Li, Wenzhu Yang, Xin Zhang
701-709
An Efficient Iterative Thresholding Algorithms for Color Images of Cotton Foreign Fibers
Xin Zhang, Daoliang Li, Wenzhu Yang, Jinxing Wang, Shuangxi Liu
710-719
Application of Grey Prediction Model in Rural Informatization Construction
Jing Du, Daoliang Li, Hongwen Li, Lifeng Shen
720-726
Study on Evaluation Method for Chinese Agricultural Informatization
Xiaoqing Yuan, Liyong Liu, Daoliang Li
727-734
Research on Calculation Method for Agricultural Informatization Contribution Rate
Liyong Liu, Qilong Pan, Daoliang Li
735-741
An Empirical Research on the Evaluation Index Regarding the Service Quality of Agricultural Information Websites in China
Liyong Liu, Xiaoqing Yuan, Daoliang Li
742-750
Hyperspectral Sensing Techniques Applied to Bio-masses Characterization: The Olive Husk Case
Giuseppe Bonifazi, Silvia Serranti
751-764
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
