Conference papers
Generalized Bayesian Pursuit: A Novel Scheme for Multi-Armed Bernoulli Bandit Problems
Abstract : In the last decades, a myriad of approaches to the multi-armed bandit problem have appeared in several different fields. The current top performing algorithms from the field of Learning Automata reside in the Pursuit family, while UCB-Tuned and the ε-greedy class of algorithms can be seen as state-of-the-art regret minimizing algorithms. Recently, however, the Bayesian Learning Automaton (BLA) outperformed all of these, and other schemes, in a wide range of experiments. Although seemingly incompatible, in this paper we integrate the foundational learning principles motivating the design of the BLA, with the principles of the so-called Generalized Pursuit algorithm (GPST), leading to the Generalized Bayesian Pursuit algorithm (GBPST). As in the BLA, the estimates are truly Bayesian in nature, however, instead of basing exploration upon direct sampling from the estimates, GBPST explores by means of the arm selection probability vector of GPST. Further, as in the GPST, in the interest of higher rates of learning, a set of arms that are currently perceived as being optimal is pursued to minimize the probability of pursuing a wrong arm. It turns out that GBPST is superior to GPST and that it even performs better than the BLA by controlling the learning speed of GBPST. We thus believe that GBPST constitutes a new avenue of research, in which the performance benefits of the GPST and the BLA are mutually augmented, opening up for improved performance in a number of applications, currently being tested.
Document type :
Conference papers
Complete list of metadatas
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-01571485
Contributor : Hal Ifip <>
Submitted on : Wednesday, August 2, 2017 - 4:22:26 PM
Last modification on : Friday, June 5, 2020 - 5:10:10 PM
File
978-3-642-23960-1_16_Chapter.p...
Identifiers
Citation
Xuan Zhang, B. Oommen, Ole-Christoffer Granmo. Generalized Bayesian Pursuit: A Novel Scheme for Multi-Armed Bernoulli Bandit Problems. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.122-131, ⟨10.1007/978-3-642-23960-1_16⟩. ⟨hal-01571485⟩
Share
Metrics
Record views
152
Files downloads
265
