Conference papers
Efficient Multi-rate Hybrid Continuous-Time/Discrete-Time Cascade 2-2 Sigma-Delta Modulators for Wideband Telecom
Abstract : This chapter discusses the use of hybrid continuous-time /discrete-time fourth-order cascade two-stage 2-2 ΣΔ modulators for wideband low-power wireless applications. The modulator architecture under study is based on a new concept of multi-rate operation, in which the front-end stage – implemented using continuous-time (Gm-C) integrators – operates at a higher rate than the back-end (switched-capacitor) stage. This strategy benefits from the faster operation of continuous-time circuits while keeping power efficiency and high robustness against circuit element tolerances. A comparison with conventional multi-rate and single-rate (continuous-time) ΣΔ modulators is carried out based on the impact of main circuit-level error mechanisms, namely: mismatch, finite OTA dc gain and finite gain-bandwidth product. Closed-form analytical expressions are derived for the nonideal in-band noise power of the different architectures under study, demonstrating a good agreement with simulations and showing the benefits of the presented approach. Simulation results show that the proposed modulator is able to operate with a maximum sampling rate of up to 1GHz, digitizing signals with a 44-to-92dB peak signal-to-(noise+distortion) ratio within a programmable 5-to-60MHz bandwidth.
Complete list of metadatas
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01519763
Contributor : Hal Ifip <>
Submitted on : Tuesday, May 9, 2017 - 11:39:53 AM
Last modification on : Thursday, March 5, 2020 - 5:40:32 PM
Document(s) archivé(s) le : Thursday, August 10, 2017 - 12:43:31 PM
File
978-3-642-32770-4_8_Chapter.pd...
Identifiers
Citation
J. García-Sánchez, José Rosa. Efficient Multi-rate Hybrid Continuous-Time/Discrete-Time Cascade 2-2 Sigma-Delta Modulators for Wideband Telecom. 19th International Conference on Very Large Scale Integration (VLSISOC), Oct 2011, Hong Kong, China. pp.124-143, ⟨10.1007/978-3-642-32770-4_8⟩. ⟨hal-01519763⟩
Share
Metrics
Record views
185
Files downloads
233
