Conference papers
A 100dB SFDR 0.5V pk-pk Band-Pass DAC Implemented on a Low Voltage CMOS Process
Abstract : Direct Digital Synthesis (DDS) systems generate fine frequency resolution signals over a broad spectrum that are used in a wide variety of applications such as multi-mode RF, communications, measurements and test. A high performance DDS band-pass Digital to Analog Converter (DAC) architecture and implementation is presented that delivers high spectral purity over a narrow-band response. The low power D/A Converter is portable to standard CMOS processes and designed to achieve over 100dB narrow-band SFDR performance using Sigma-Delta (∑ Δ) modulation and multi-bit current steering techniques. A 3rd order digital ∑ Δ modulator is combined with a 4th order digital Dynamic Element Matching (DEM) block to shape the noise while calibrating for process mismatch variations. A low silicon area output stage is used to deliver a high performance specification.
Complete list of metadatas
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01519770
Contributor : Hal Ifip <>
Submitted on : Tuesday, May 9, 2017 - 11:40:01 AM
Last modification on : Thursday, March 5, 2020 - 5:40:33 PM
Document(s) archivé(s) le : Thursday, August 10, 2017 - 12:46:06 PM
File
978-3-642-32770-4_9_Chapter.pd...
Identifiers
Citation
Brendan Mullane, Vincent O’brien. A 100dB SFDR 0.5V pk-pk Band-Pass DAC Implemented on a Low Voltage CMOS Process. 19th International Conference on Very Large Scale Integration (VLSISOC), Oct 2011, Hong Kong, China. pp.144-157, ⟨10.1007/978-3-642-32770-4_9⟩. ⟨hal-01519770⟩
Share
Metrics
Record views
274
Files downloads
415
