Full Text Documents
Chargement de la page
Search
Table of Contents
Intelligent Information Processing VI
Zhongzhi Shi, David Leake, SunilVadera (Eds.)
Front Matter
Keynote Presentations
The AI Journey: The Road Traveled and the (Long) Road Ahead
Ramon Mantaras
1-1
Transfer Learning and Applications
Qiang Yang
2-2
Semantics of Cyber-Physical Systems
Tharam Dillon, Elizabeth Chang, Jaipal Singh, Omar Hussain
3-12
Big Data Mining in the Cloud
Zhongzhi Shi
13-14
Research on Semantic Programming Language
Shi Ying
15-15
Machine Learning
Effectively Constructing Reliable Data for Cross-Domain Text Classification
Fuzhen Zhuang, Qing He, Zhongzhi Shi
16-27
Improving Transfer Learning by Introspective Reasoner
Zhongzhi Shi, Bo Zhang, Fuzhen Zhuang
28-39
PPLSA: Parallel Probabilistic Latent Semantic Analysis Based on MapReduce
Ning Li, Fuzhen Zhuang, Qing He, Zhongzhi Shi
40-49
Analysis on Limitation Origins of Information Theory
Yong Wang, Huadeng Wang, Qiong Cao
50-57
Data Mining
Intelligent Inventory Control: Is Bootstrapping Worth Implementing?
Tatpong Katanyukul, Edwin Chong, William Duff
58-67
Support Vector Machine with Mixture of Kernels for Image Classification
Dongping Tian, Xiaofei Zhao, Zhongzhi Shi
68-76
The BDIP Software Architecture and Running Mechanism for Self-Organizing MAS
Yi Guo, Xinjun Mao, Fu Hou, Cuiyun Hu, Jianming Zhao
77-86
Optimization of Initial Centroids for K-Means Algorithm Based on Small World Network
Shimo Shen, Zuqiang Meng
87-96
ECCO: A New Evolutionary Classifier with Cost Optimisation
Adam Omielan, Sunil Vadera
97-105
Automatic Reasoning
Reasoning Theory for D3L with Compositional Bridge Rules
Xiaofei Zhao, Dongping Tian, Limin Chen, Zhongzhi Shi
106-115
Semantic Keyword Expansion: A Logical Approach
Limin Chen
116-124
An ABox Abduction Algorithm for the Description Logic ALCI
Yanwei Ma, Tianlong Gu, Binbin Xu, Liang Chang
125-130
Reasoning about Assembly Sequences Based on Description Logic and Rule
Yu Meng, Tianlong Gu, Liang Chang
131-136
Semantic Web
Dynamic Logic for the Semantic Web
Liang Chang, Qicheng Zhang, Tianlong Gu, Zhongzhi Shi
137-146
On the Support of Ad-Hoc Semantic Web Data Sharing
Jing Zhou, Kun Yang, Lei Shi, Zhongzhi Shi
147-156
An Architecture Description Language Based on Dynamic Description Logics
Zhuxiao Wang, Hui Peng, Jing Guo, Ying Zhang, Kehe Wu, Huan Xu, Xiaofeng Wang
157-166
Information Retrieval
Query Expansion Based-on Similarity of Terms for Improving Arabic Information Retrieval
Khaled Shaalan, Sinan Al-Sheikh, Farhad Oroumchian
167-176
Towards an Author Intention Based Computational Model of Story Generation
Feng Zhu, Cungen Cao
177-185
Adaptive Algorithm for Interactive Question-Based Search
Jacek Rzeniewicz, Julian Szymański, Włodzisław Duch
186-195
Research of Media Material Retrieval Scheme Based on XPath
Shuang Feng, Weina Zhang
196-201
Construction of SCI Publications Information System for Statistic
Xie Wu, Huimin Zhang, Jingbo Jiang
202-207
Knowledge Representation
Symbolic ZBDD Representations for Mechanical Assembly Sequences
Fengying Li, Tianlong Gu, Guoyong Cai, Liang Chang
208-215
The Representation of Indiscernibility Relation Using ZBDDs
Qianjin Wei, Tianlong Gu, Fengying Li, Guoyong Cai
216-225
Symbolic OBDD Assembly Sequence Planning Algorithm Based on Unordered Partition with 2 Parts of a Positive Integer
Zhoubo Xu, Tianlong Gu, Rongsheng Dong
226-233
A Representation Model of Geometrical Tolerances Based on First Order Logic
Yuchu Qin, Yanru Zhong, Liang Chang, Meifa Huang
234-239
Social Networks
Modeling Group Emotion Based on Emotional Contagion
Yanjun Yin, Weiqing Tang, Weiqing Li
240-247
Hierarchical Overlapping Community Discovery Algorithm Based on Node Purity
Guoyong Cai, Ruili Wang, Guobin Liu
248-257
Finding Topic-Related Tweets Using Conversational Thread
Jingyuan Li, Yue Liu, Xueqi Cheng, Peng Cao, Shenghua Liu, Jinhua Gao, Huawei Shen
258-267
Messages Ranking in Social Network
Bo Li, Fengxian Shi, Enhong Chen
268-275
Trust Software
Diagnosis of Internetware Systems Using Dynamic Description Logic
Kun Yang, Weiqun Cui, Junheng Teng, Chenzhe Hang
276-285
Reasoning about Semantic Web Services with an Approach Based on Temporal Description Logic
Juan Wang, Liang Chang, Chuangying Zhu, Rongsheng Dong
286-294
Constraint Programming-Based Virtual Machines Placement Algorithm in Datacenter
Yonghong Yu, Yang Gao
295-304
Recommendation-Based Trust Model in P2P Network Environment
Yueju Lei, Guangxi Chen
305-310
Internet of Things
Frequency-Adaptive Cluster Head Election in Wireless Sensor Network
Tianlong Yun, Wenjia Niu, Xinghua Yang, Hui Tang, Song Ci
311-319
A Cluster-Based Multilevel Security Model for Wireless Sensor Networks
Chao Lee, Lihua Yin, Yunchuan Guo
320-330
A New Security Routing Algorithm Based on MST for Wireless Sensor Network
Meimei Zeng, Hua Jiang
331-336
Image Processing
A Novel Model for Semantic Learning and Retrieval of Images
Zhixin Li, Zhiping Shi, Zhengjun Tang, Weizhong Zhao
337-346
Automatic Image Annotation and Retrieval Using Hybrid Approach
Zhixin Li, Weizhong Zhao, Zhiqing Li, Zhiping Shi
347-356
Double Least Squares Pursuit for Sparse Decomposition
Wanyi Li, Peng Wang, Hong Qiao
357-363
Ensemble of k-Labelset Classifiers for Multi-label Image Classification
Dapeng Zhang, Xi Liu
364-371
Pattern Recognition
Robust Palmprint Recognition Based on Directional Representations
Hengjian Li, Lianhai Wang, Zutao Zhang
372-381
FPGA-Based Image Acquisition System Designed for Wireless
Haohao Yuan, Jianhe Zhou, Suqiao Li
382-386
A Context-Aware Multi-Agent Systems Architecture for Adaptation of Autonomic Systems
Kaiyu Wan, Vasu Alagar
387-397
Eyes Closeness Detection Using Appearance Based Methods
Xue Liu, Xiaoyang Tan, Songcan Chen
398-408
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
