Conference papers
Effects of Time Delays in the Electric Power Grid
Abstract : Communication delays in an electric power grid affect the performance of control systems and can cause power losses. This paper analyzes the causes and effects of communication delays. The analysis employs a simulated power network comprising several generators for which braking resistors with intelligent (fuzzy logic) controllers are used for transient stability control. A balanced 3LG (three-phase-to-ground) fault at different points on the transmission lines is considered. Simulation results show that, although a fuzzy-logic-controlled braking resistor can improve transient stability, the communication delay associated with the online calculation of the total kinetic energy deviation, which is the input parameter for fuzzy control, has an influence on the transient stability performance. The paper also examines the delay that a system can tolerate and the cyber attacks that can cause additional delays.
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01483810
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, March 6, 2017 - 3:01:43 PM
Last modification on : Thursday, August 22, 2019 - 2:44:30 PM
Long-term archiving on: : Wednesday, June 7, 2017 - 2:17:45 PM
File
978-3-642-35764-0_11_Chapter.p...
Identifiers
Citation
Hasan Ali, Dipankar Dasgupta. Effects of Time Delays in the Electric Power Grid. 6th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2012, Washington, DC, United States. pp.139-154, ⟨10.1007/978-3-642-35764-0_11⟩. ⟨hal-01483810⟩
Share
Metrics
Record views
39
Files downloads
539
