Conference papers
Introducing Periodic Parameters in a Marine Ecosystem Model Using Discrete Linear Quadratic Control
Abstract : This paper presents the application of the Discrete Linear Quadratic Control (DLQC) method for a parameter optimization problem in a marine ecosystem model. The ecosystem model simulates the distribution of nitrogen, phytoplankton, zooplankton and detritus in a water column with temperature and turbulent diffusivity profiles taken from a three-dimensional ocean circulation model. We present the linearization method which is based on the available observations. The linearization is necessary to apply the DLQC method on the nonlinear system of state equations. We show the form of the linearized time-variant problems and the resulting two algebraic Riccati Equations. By using the DLQC method, we are able to introduce temporally varying periodic model parameters and to significantly improve – compared to the use of constant parameters – the fit of the model output to given observational data.
Complete list of metadatas
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-01347570
Contributor : Hal Ifip <>
Submitted on : Thursday, July 21, 2016 - 11:26:37 AM
Last modification on : Friday, November 3, 2017 - 11:48:19 AM
File
978-3-642-36062-6_48_Chapter.p...
Identifiers
Citation
Mustapha Jarbi, Thomas Slawig, Andreas Oschlies. Introducing Periodic Parameters in a Marine Ecosystem Model Using Discrete Linear Quadratic Control. 25th System Modeling and Optimization (CSMO), Sep 2011, Berlin, Germany. pp.481-490, ⟨10.1007/978-3-642-36062-6_48⟩. ⟨hal-01347570⟩
Share
Metrics
Record views
168
Files downloads
154
