Technological Innovation for the Internet of Things 4th IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems, DoCEIS 2013, Costa de Caparica, Portugal, April 15-17, 2013. Proceedings
Conference papers
Preliminary Studies and Test Results of a Superconducting Hysteresis Motor with Multiphase Windings and Variable Number of Magnetic Poles
Abstract : In this paper a procedure for determining the number of different synchronous speeds that can be obtained from the stator of a drum motor as a function of the number of slots is presented. This preliminary study is foreseen for a hysteresis high-temperature superconducting motor, but the approach is directly applied in conventional motors. The targeted device has multiphase windings, in order to achieve full flexibility in torque-speed space through electronic variation of magnetic poles. Simulations are performed in order to achieve a qualitative understanding of the behaviour of the motor, namely in what concerns to torque and settling times from initial to synchronous speed. A prototype with eighteen slots in the stator and a bulk YBCO rotor is described and built, and experimental values of torque are obtained.
https://hal.archives-ouvertes.fr/hal-01348788
Contributor : Hal Ifip <>
Submitted on : Monday, July 25, 2016 - 4:48:32 PM Last modification on : Monday, July 25, 2016 - 5:05:51 PM
Raul Dionísio, João Pina, David Inácio, Amadeu Rodrigues. Preliminary Studies and Test Results of a Superconducting Hysteresis Motor with Multiphase Windings and Variable Number of Magnetic Poles. 4th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2013, Costa de Caparica, Portugal. pp.431-440, ⟨10.1007/978-3-642-37291-9_46⟩. ⟨hal-01348788⟩
