Advances in Production Management Systems: Competitive Manufacturing for Innovative Products and Services IFIP WG 5.7 International Conference, APMS 2012, Rhodes, Greece, September 24-26, 2012, Part II
Conference papers
Improving Tree-Based Classification Rules Using a Particle Swarm Optimization
Abstract : The main advantage of tree classifiers is to provide rules that are simple in form and are easily interpretable. Since decision tree is a top-down algorithm using a divide and conquer induction process, there is a risk of reaching a local optimal solution. This paper proposes a procedure of optimally determining the splitting variables and their thresholds for a decision tree using an adaptive particle swarm optimization. The proposed method consists of three phases – tree construction, threshold optimization and rule simplification. To validate the proposed algorithm, several artificial and real datasets are used. We compare our results with the original CART results and show that the proposed method is promising for improving prediction accuracy.
https://hal.inria.fr/hal-01470625
Contributor : Hal Ifip <>
Submitted on : Friday, February 17, 2017 - 3:53:01 PM Last modification on : Thursday, March 5, 2020 - 4:45:36 PM Long-term archiving on: : Thursday, May 18, 2017 - 3:10:19 PM
