Conference papers
Power Reduction in Embedded Systems Using a Design Methodology Based on Synchronous Finite State Machines
Abstract : To achieve the highest levels of power reduction, embedded systems must be conceived as low-power devices, since the early stages of the design process. The proposed Model-Based-Development process uses Synchronous Finite State Machines (SFSM) to model the behavior of low-power devices. This methodology is aimed at devices at the lower-end of the complexity spectrum, as long as the device behavior can be modeled as SFSM. The implementation requires a single timer to provide the SFSM clock. The energy reduction is obtained by changing the state of the processor to a low-power state, such as deep-sleep.The main contribution is the use of a methodology where energy consumption awareness is a concern from the early stages of the design cycle, and not an afterthought to the implementation phase.
Document type :
Conference papers
Complete list of metadatas
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01466694
Contributor : Hal Ifip <>
Submitted on : Monday, February 13, 2017 - 4:39:43 PM
Last modification on : Thursday, March 5, 2020 - 5:40:27 PM
Long-term archiving on: : Sunday, May 14, 2017 - 2:51:06 PM
File
978-3-642-38853-8_6_Chapter.pd...
Identifiers
Citation
Douglas Renaux, Fabiana Pöttker. Power Reduction in Embedded Systems Using a Design Methodology Based on Synchronous Finite State Machines. 4th International Embedded Systems Symposium (IESS), Jun 2013, Paderborn, Germany. pp.61-72, ⟨10.1007/978-3-642-38853-8_6⟩. ⟨hal-01466694⟩
Share
Metrics
Record views
166
Files downloads
388
