Abstract : This paper first discusses two cognitive science paradigms and then present third approach related to interaction with the world as known as embodied cognition. The focus is to analyze work settings with the help of cognitive work analysis and human work interaction design approaches. The case of power plant control room is discussed and analyzed in the context of human system interactions, work and task analysis. This approach helps in reducing cognitive workload on operator which can result in reduction in errors in managing the control room of the power plant.
https://hal.inria.fr/hal-01463381
Contributor : Hal Ifip <>
Submitted on : Thursday, February 9, 2017 - 3:04:59 PM Last modification on : Thursday, March 5, 2020 - 4:40:53 PM Long-term archiving on: : Wednesday, May 10, 2017 - 2:19:10 PM
Anant Garg, K. Govil. Empirical Evaluation of Complex System Interfaces for Power Plant Control Room Using Human Work Interaction Design Framework. 3rd Human Work Interaction Design (HWID), Dec 2012, Copenhagen, Denmark. pp.90-97, ⟨10.1007/978-3-642-41145-8_8⟩. ⟨hal-01463381⟩
