Conference papers
File Fragment Analysis Using Normalized Compression Distance
Abstract : The first step when recovering deleted files using file carving is to identify the file type of a block, also called file fragment analysis. Several researchers have demonstrated the applicability of Kolmogorov complexity methods such as the normalized compression distance (NCD) to this problem. NCD methods compare the results of compressing a pair of data blocks with the compressed concatenation of the pair. One parameter that is required is the compression algorithm to be used. Prior research has identified the NCD compressor properties that yield good performance. However, no studies have focused on its applicability to file fragment analysis. This paper describes the results of experiments on a large corpus of files and file types with different block lengths. The experimental results demonstrate that, in the case of file fragment analysis, compressors with the desired properties do not perform statistically better than compressors with less computational complexity.
Complete list of metadatas
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01460604
Contributor : Hal Ifip <>
Submitted on : Tuesday, February 7, 2017 - 5:25:46 PM
Last modification on : Thursday, March 5, 2020 - 4:46:38 PM
Document(s) archivé(s) le : Monday, May 8, 2017 - 2:53:05 PM
File
978-3-642-41148-9_12_Chapter.p...
Identifiers
Citation
Stefan Axelsson, Kamran Bajwa, Mandhapati Srikanth. File Fragment Analysis Using Normalized Compression Distance. 9th International Conference on Digital Forensics (DF), Jan 2013, Orlando, FL, United States. pp.171-182, ⟨10.1007/978-3-642-41148-9_12⟩. ⟨hal-01460604⟩
Share
Metrics
Record views
131
Files downloads
308
