Conference papers
Continental-Scale Living Forest Biomass and Carbon Stock: A Robust Fuzzy Ensemble of IPCC Tier 1 Maps for Europe
Abstract : Forest ecosystems play a key role in the global carbon cycle. Spatially explicit data and assessments of forest biomass and carbon are therefore crucial for designing and implementing effective sustainable forest management options and forest related policies. In this contribution, we present European-wide maps of forest biomass and carbon stock spatially disaggregated at 1km x 1km. The maps originated from a spatialisation improvement of the IPCC methodology for estimating the forest biomass at IPCC Tier 1 level (IPCC-T1). Using a categorical map of ecological zones within the mapping technique may originate boundary effects between the ecological zones. This may induce undue artifacts in the outcomes, as evident in previously published maps generated with the IPCC-T1 methodology. Here we present a novel method for IPCC-T1 biomass mapping which mitigates these artifacts. We propose the use of a fuzzy similarity map of the FAO ecological zones computed by estimating the relative distance similarity (RDS) of each grid-cells climate and geography with respect to the FAO ecological zones. A robust ensemble approach was used to merge an array of simple models with spatially distributed fuzzy set-membership. This allowed the boundary artifacts to be reduced, while mitigating the impact of model semantic extrapolation. The chain of semantically enhanced data-transformations is described following the semantic array programming paradigm. Preliminary results obtained from the application of this novel approach are presented along with a discussion of its impact on the derived maps.
Complete list of metadatas
Cited literature [52 references]  Display  Hide  Download
https://hal.inria.fr/hal-01457457
Contributor : Hal Ifip <>
Submitted on : Monday, February 6, 2017 - 2:42:49 PM
Last modification on : Tuesday, August 13, 2019 - 11:10:03 AM
Document(s) archivé(s) le : Sunday, May 7, 2017 - 2:09:03 PM
File
978-3-642-41151-9_26_Chapter.p...
Identifiers
Citation
Daniele Rigo, José Barredo, Lorenzo Busetto, Giovanni Caudullo, Jesús San-Miguel-Ayanz. Continental-Scale Living Forest Biomass and Carbon Stock: A Robust Fuzzy Ensemble of IPCC Tier 1 Maps for Europe. 10th International Symposium on Environmental Software Systems (ISESS), Oct 2013, Neusiedl am See, Austria. pp.271-284, ⟨10.1007/978-3-642-41151-9_26⟩. ⟨hal-01457457⟩
Share
Metrics
Record views
91
Files downloads
334
