Conference papers
A Study on the Effect of Inspection Time on Defect Detection in Visual Inspection
Abstract : In order to consider the visual inspection utilizing the peripheral vision, this paper examines the inspection times that affect defect detection. The fixation duration and the distance between defect and the fixation point are experimental factors in determining the inspection time. As the result, in case of a large sized defect, the detection rate is high regardless of the fixation duration and the distance between the defect and the fixation point. In case of a small sized defect, when the fixation duration is longer and the distance between the defect and the fixation point is closer, the defect detection rate is higher. Moreover, as the result of conducting multiple linear regression analysis about the experiment factors, it is obtained that judging from standardized partial regression coefficient of factors, higher defect size, less the distance between defect and the fixation point, the higher fixation duration, is proved to improve the defect detection.
Complete list of metadatas
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01452141
Contributor : Estelle Nivault <>
Submitted on : Wednesday, February 1, 2017 - 4:11:17 PM
Last modification on : Thursday, March 5, 2020 - 4:45:22 PM
File
978-3-642-41266-0_4_Chapter.pd...
Identifiers
Citation
Ryosuke Nakajima, Keisuke Shida, Toshiyuki Matsumoto. A Study on the Effect of Inspection Time on Defect Detection in Visual Inspection. 20th Advances in Production Management Systems (APMS), Sep 2013, State College, PA, United States. pp.29-39, ⟨10.1007/978-3-642-41266-0_4⟩. ⟨hal-01452141⟩
Share
Metrics
Record views
165
Files downloads
855
