Computer and Computing Technologies in Agriculture VII 7th IFIP WG 5.14 International Conference, CCTA 2013, Beijing, China, September 18-20, 2013, Part II
Conference papers
Agricultural Field Environment High-Quality Image Remote Acquisition
Abstract : In order to realize the acquisition of high-resolution and
high-precision image in agricultural field environment, the agricultural
field environment high-quality image remote acquisition system was
designed, based on Canon DSLR camera. This paper made detailed design
about core algorithm, including remote acquisition system architecture,
camera access, image transmission and command response. The scheme used
Fit-PC to control Canon 550D DSLR camera for image acquisition and WIFI
wireless transmission module to transmit collected images to the remote
server. Meanwhile, the server could also remotely operate camera to
collect images in different ways through wireless transmission command,
according to different needs. The experimental results showed that the
system had three main advantages as high resolution, precision and image
transmission rate in collecting images. The resolution of images
collected in each node was up to 5184×3456, and the effective
breadth of Canon camera image was 17 times as the Logitech camera. In
addition, at a distance of 16 meters, image captured by Logitech camera
could not see the target while the same one captured by Canon camera
could still clearly display. Moreover, the average speed of wireless
images transmission to the server was 0.97MB/S. Therefore, this system
could meet the requirements of high-quality image acquisition and
transmission in agricultural field environment.
https://hal.inria.fr/hal-01220814
Contributor : Hal Ifip <>
Submitted on : Tuesday, October 27, 2015 - 8:22:40 AM Last modification on : Wednesday, January 17, 2018 - 10:45:35 AM Long-term archiving on: : Thursday, January 28, 2016 - 10:19:20 AM
Fu Junqian, Xiao Deqin, Deng Xiaohui. Agricultural Field Environment High-Quality Image Remote Acquisition. 7th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2013, Beijing, China. pp.50-60, ⟨10.1007/978-3-642-54341-8_6⟩. ⟨hal-01220814⟩
