Conference papers
Active Power Filter with Relay Current Regulator and Common DC Link for Compensation of Harmonic Distortion in Power Grids
Abstract : The growing number of consumers representing non-linear loads has led to an increase in the level of harmonics and poor power quality. It is not news to apply active power filtering (APF), but the drawback is the lower efficiency and complexity. The described here active power filter control system is simpler and more efficient. It is based on a relay current regulator and its converter uses the existing DC bus of the rectifier. The theoretical basis of the APF is described. A model of the proposed APF (with its suggested control system and the common DC link) is simulated in Matlab. The result of this simulation demonstrates that the level of the Total Harmonic Distortion (THD) of the input current is less than 3 %. The input current matches the phase of the input (mains) voltage: i.e. the consumption of reactive power from the grid is minimized. The simulation is confirmed by experimental study of the relay current controller. The corresponding results are provided.
Complete list of metadatas
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01274805
Contributor : Hal Ifip <>
Submitted on : Tuesday, February 16, 2016 - 11:28:25 AM
Last modification on : Thursday, May 12, 2016 - 10:38:34 AM
Document(s) archivé(s) le : Tuesday, May 17, 2016 - 5:23:29 PM
File
978-3-642-54734-8_47_Chapter.p...
Identifiers
Citation
Maksim Habibullin, Igor Pavlov, Viktor Mescheryakov, Stanimir Valtchev. Active Power Filter with Relay Current Regulator and Common DC Link for Compensation of Harmonic Distortion in Power Grids. 5th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2014, Costa de Caparica, Portugal. pp.427-434, ⟨10.1007/978-3-642-54734-8_47⟩. ⟨hal-01274805⟩
Share
Metrics
Record views
171
Files downloads
191
