Service Science and Knowledge Innovation 15th IFIP WG 8.1 International Conference on Informatics and Semiotics in Organisations, ICISO 2014, Shanghai, China, May 23-24, 2014
Conference papers
A Design Science Oriented Framework for Experimental Research in Information Quality
Abstract : Design science has been used as a new research paradigm in information quality research. Within design science, experimental validation has been recognized as one of the most important research methodologies. However, as there is a lack of a coherent framework for conducting experimental research, different information quality studies may produce different results, which can be even conflicting. In order to reduce this ambiguity, we have proposed a framework that is used to (1) refine the experimental methodology in information quality research, (2) advance the rigorous information quality research in design science, and (3) demonstrate an exemplary experimental validation in design science.
https://hal.inria.fr/hal-01350919
Contributor : Hal Ifip <>
Submitted on : Tuesday, August 2, 2016 - 11:24:34 AM Last modification on : Wednesday, August 3, 2016 - 1:03:49 AM Long-term archiving on: : Thursday, November 3, 2016 - 6:20:06 PM
Mouzhi Ge, Markus Helfert. A Design Science Oriented Framework for Experimental Research in Information Quality. 15th International Conference on Informatics and Semiotics in Organisations (ICISO), May 2014, Shanghai, China. pp.145-154, ⟨10.1007/978-3-642-55355-4_15⟩. ⟨hal-01350919⟩
