Precision Assembly Technologies and Systems 7th IFIP WG 5.5 International Precision Assembly Seminar, IPAS 2014, Chamonix, France, February 16-18, 2014
Conference papers
Precision Handling of Electronic Components for PCB Rework
Abstract : The paper focuses on the study of strategies and tools to handle miniaturized components in the electronic industry. In particular, the paper presents an innovative device and method to manipulate microcomponents by vacuum. The device includes an original releasing system, that does not require any external actuation, to assist their release. Indeed, at the microscale, adhesion forces predominate over the gravitational force due to the small masses of the microcomponents, often leading to the failure of the release phase if a release strategy is not implemented. The device, able to eliminate the adhesion problem, is compared with a traditional vacuum microgripper in terms of grasping and releasing error and percentage. The results of preliminary experimental tests are discussed, demonstrating that the innovative microgripper represents an interesting solution for handling electronic components as well as different microparts.
https://hal.inria.fr/hal-01260731
Contributor : Hal Ifip <>
Submitted on : Friday, January 22, 2016 - 3:04:23 PM Last modification on : Tuesday, September 22, 2020 - 9:04:03 AM Long-term archiving on: : Saturday, April 23, 2016 - 11:00:30 AM
Gianmauro Fontana, Serena Ruggeri, Giovanni Legnani, Irene Fassi. Precision Handling of Electronic Components for PCB Rework. 7th International Precision Assembly Seminar (IPAS), Feb 2014, Chamonix, France. pp.52-60, ⟨10.1007/978-3-662-45586-9_8⟩. ⟨hal-01260731⟩
