Advances in Production Management Systems: Innovative and Knowledge-Based Production Management in a Global-Local World (Part I). IFIP WG 5.7 International Conference, APMS 2014 Ajaccio, France, September 20-24, 2014
Conference papers
Quantifying the Bullwhip Effect of Multi-echelon System with Stochastic Dependent Lead Time
Abstract : Considering a multi-echelon system, the bullwhip effect is recognized as a significant factor with regards to the inventory management. This paper focuses on the effect of stochastic dependent lead time on the bullwhip effect. Simulation based approach is used to quantify the bullwhip effect with different demand and lead time distributions. The experiment results show that the dependent lead time has much effect on the 2nd echelon (from the downstream to the upstream) and bullwhip effect decrease significantly if the variance of this echelon decreases.
https://hal.inria.fr/hal-01388570 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, October 27, 2016 - 11:36:08 AM Last modification on : Thursday, March 5, 2020 - 4:44:45 PM
Ngoc Do, Peter Nielsen, Zbigniew Michna, Izabela Nielsen. Quantifying the Bullwhip Effect of Multi-echelon System with Stochastic Dependent Lead Time. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.419-426, ⟨10.1007/978-3-662-44739-0_51⟩. ⟨hal-01388570⟩
