Advances in Production Management Systems: Innovative and Knowledge-Based Production Management in a Global-Local World (Part I). IFIP WG 5.7 International Conference, APMS 2014 Ajaccio, France, September 20-24, 2014
Conference papers
A Multidisciplinary Framework for Robust Planning and Decision-Making in Dynamically Changing Engineering Construction Projects
Abstract : This paper proposes a multidisciplinary framework for robust planning and decision-making in dynamically changing engineering construction projects. The aim is to facilitate ’optimal’ levels and ’trade-offs’ between the major factors affecting decision-making throughout the project phases, to manage design changes and other disturbances, and to generate the maximum possible value. Offshore shipbuilding case analysis is applied to refine the model and to illustrate its value in decision-making.
https://hal.inria.fr/hal-01388586 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, October 27, 2016 - 11:42:09 AM Last modification on : Thursday, December 3, 2020 - 9:24:12 AM
Hajnalka Vaagen, Bjørnar Aas. A Multidisciplinary Framework for Robust Planning and Decision-Making in Dynamically Changing Engineering Construction Projects. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.515-522, ⟨10.1007/978-3-662-44739-0_63⟩. ⟨hal-01388586⟩
