Conference papers
Improved Denoising with Robust Fitting in the Wavelet Transform Domain
Abstract : In this paper we present a new method for thresholding the coefficients in the wavelet transform domain based on the robust local polynomial regression technique. It is proven that the robust locally-weighted smoother excellently removes the outliers or extreme values by performing iterative reweighting. The proposed method combines the main advantages of multiresolution analysis and robust fitting. Simulation results show efficient denoising at low resolution levels. Besides, it provides simultaneously high density impulse noise removal in contrast to other adaptive shrinkage procedures. Performance has been determined by using quantitative measures, such as signal to noise ratio and root mean square error.
Complete list of metadatas
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/hal-01343481
Contributor : Hal Ifip <>
Submitted on : Friday, July 8, 2016 - 2:58:44 PM
Last modification on : Friday, July 8, 2016 - 3:33:08 PM
File
336594_1_En_19_Chapter.pdf
Identifiers
Citation
Adrienn Dineva, Annamária Várkonyi-Kóczy, József Tar. Improved Denoising with Robust Fitting in the Wavelet Transform Domain. 6th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2015, Costa de Caparica, Portugal. pp.179-187, ⟨10.1007/978-3-319-16766-4_19⟩. ⟨hal-01343481⟩
Share
Metrics
Record views
87
Files downloads
133
