Conference papers
New Multi-objective Decision Support Methodology to Solve Problems of Reconfiguration in the Electric Distribution Systems
Abstract : The distribution systems (DS) reconfiguration problem is formulated in this paper as a multi-objective mixed-integer linear programming (MILP) multi-period problem, enforcing that the obtained topology is radial in order to exploit several advantages those configurations offer. The effects of distributed generation (DG) and energy storage systems (ESS) are also investigated. To address the multi-objective problem, an improved implementation of the ε-constraint method (AUGMECON-2) is used, providing an adequate representation of the Pareto set. The objective functions considered stand for the minimization of active power losses and the minimization of switching operations. The proposed methodology is tested using a real system based on the S. Miguel Island, Azores, Portugal. The potential uses of cloud-based engineering systems, both in terms of exploiting the enhanced decentralized computational opportunities they offer and of utilizing them in order to achieve communication and coordination between several entities that are engaged in DS, are thoroughly discussed.
Complete list of metadatas
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01343508
Contributor : Hal Ifip <>
Submitted on : Friday, July 8, 2016 - 3:08:15 PM
Last modification on : Friday, July 8, 2016 - 3:33:07 PM
File
336594_1_En_42_Chapter.pdf
Identifiers
Citation
Sérgio Santos, Nikolaos Paterakis, João Catalão. New Multi-objective Decision Support Methodology to Solve Problems of Reconfiguration in the Electric Distribution Systems. 6th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2015, Costa de Caparica, Portugal. pp.395-404, ⟨10.1007/978-3-319-16766-4_42⟩. ⟨hal-01343508⟩
Share
Metrics
Record views
108
Files downloads
148
