Conference papers
Stable Integration of Power Electronics-Based DG Links to the Utility Grid with Interfacing Impedance Uncertainties
Abstract : For the integration of distributed generation (DG) units to the utility grid, voltage source converter (VSC) is the key technology. In order to realize high quality power injection, different control techniques have been adopted. However, the converter-based DG interface is subject to inevitable uncertainties, which adversely influence the performance of the controller. The interfacing impedance seen by the VSC may considerably vary in real distribution networks. It can be observed that the stability of the DG interface is highly sensitive to the impacts of interfacing impedance changes so that the controller cannot inject appropriate currents. To deal with the instability problem, this paper proposes an enhanced fractional order active sliding mode control scheme for integration of DG units to the utility grid, which is much less sensitive to interfacing impedance variations. A fractional sliding surface which demonstrates the desired dynamics of the system is developed and then the controller is designed in two phases: sliding phase and reaching phase to keep the control loop stable. The proposed controller takes a role to provide high quality power injection and ensures precise current tracking and fast response despite uncertainties. Theoretical analyses and simulation results are verified to study the performance and feasibility of the proposed control scheme.
Complete list of metadatas
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01343525
Contributor : Hal Ifip <>
Submitted on : Friday, July 8, 2016 - 3:12:38 PM
Last modification on : Friday, August 23, 2019 - 3:20:03 PM
File
336594_1_En_54_Chapter.pdf
Identifiers
Citation
S. Kazem Hoseini, Edris Pouresmaeil, Jafar Adabi, João Catalão. Stable Integration of Power Electronics-Based DG Links to the Utility Grid with Interfacing Impedance Uncertainties. 6th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2015, Costa de Caparica, Portugal. pp.502-511, ⟨10.1007/978-3-319-16766-4_54⟩. ⟨hal-01343525⟩
Share
Metrics
Record views
148
Files downloads
258
