Improved Parameters Updating Algorithm for the Detection of Moving Objects
Abstract : The presence of dynamic scene is a challenging problem in video surveillance systems tasks. Mixture of Gaussian (MOG) is the most appropriate method to model dynamic background. However, local variations and the instant variations in the brightness decrease the performance of the later. We present in this paper a novel and efficient method that will significantly reduce MOG drawbacks by an improved parameters updating algorithm. Starting from a normalization step, we divide each extracted frame into several blocks. Then, we apply an improved updating algorithm for each block to control local variation. When a significant environment changes are detected in one or more blocs, the parameters of MOG assigned to these blocks are updated and the parameters of the rest remain the same. Experimental results demonstrate that the proposed approach is effective and efficient compared with state-of-the-art background subtraction methods.
Document type :
Conference papers
Complete list of metadatas
Cited literature [33 references]  Display  Hide  Download
https://hal.inria.fr/hal-01789971
Contributor : Hal Ifip <>
Submitted on : Friday, May 11, 2018 - 3:11:38 PM
Last modification on : Tuesday, May 22, 2018 - 8:40:05 PM
Long-term archiving on : Tuesday, September 25, 2018 - 10:26:07 AM
File
339159_1_En_43_Chapter.pdf
Identifiers
Citation
Brahim Farou, Hamid Seridi, Herman Akdag. Improved Parameters Updating Algorithm for the Detection of Moving Objects. 5th International Conference on Computer Science and Its Applications (CIIA), May 2015, Saida, Algeria. pp.527-537, ⟨10.1007/978-3-319-19578-0_43⟩. ⟨hal-01789971⟩
Share
Metrics
Record views
206
Files downloads
92
