Conference papers
Using Fuzzy Logic to Improve BLE Indoor Positioning System
Abstract : Accuracy and precision are key parameters in the definition of indoor positioning systems. We want to provide a mobile robot with the capacity to autonomously determining its location inside buildings, to allow it to autonomously navigate. The solution developed is based on spreading emitter beacons of Bluetooth Low Energy in the building and use location finding techniques to determine the robot’s location. The main challenge is the capacity to obtain accurate readings of signal strength and the low repeatability of readings even under unchanged conditions. To improve the signal strength measurements it is necessary to deal with this imprecision. Our approach is based on the use of Fuzzy Logic to deal with the accuracy problem. Once better signal strength readings are achieved, using this method, approximate distances are calculated based on signal strength and the trilateration method is implemented to provide the location of the mobile robot.
Complete list of metadatas
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01438241
Contributor : Hal Ifip <>
Submitted on : Tuesday, January 17, 2017 - 3:37:42 PM
Last modification on : Tuesday, January 17, 2017 - 3:49:45 PM
Document(s) archivé(s) le : Tuesday, April 18, 2017 - 3:05:45 PM
File
419233_1_En_18_Chapter.pdf
Identifiers
Citation
Sérgio Onofre, Bernardo Caseiro, João Pimentão, Pedro Sousa. Using Fuzzy Logic to Improve BLE Indoor Positioning System. 7th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2016, Costa de Caparica, Portugal. pp.169-177, ⟨10.1007/978-3-319-31165-4_18⟩. ⟨hal-01438241⟩
Share
Metrics
Record views
156
Files downloads
313
