Conference papers
Normalization Techniques for Multi-Criteria Decision Making: Analytical Hierarchy Process Case Study
Abstract : Multi-Criteria Decision Making (MCDM) methods use normalization techniques to allow aggregation of criteria with numerical and comparable data. With the advent of Cyber Physical Systems, where big data is collected from heterogeneous sensors and other data sources, finding a suitable normalization technique is also a challenge to enable data fusion (integration). Therefore, data fusion and aggregation of criteria are similar processes of combining values either from criteria or from sensors to obtain a common score. In this study, our aim is to discuss metrics for assessing which are the most appropriate normalization techniques in decision problems, specifically for the Analytical Hierarchy Process (AHP) multi-criteria method. AHP uses a pairwise approach to evaluate the alternatives regarding a set of criteria and then fuses (aggregation) the evaluations to determine the final ratings (scores).
Complete list of metadatas
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01438251
Contributor : Hal Ifip <>
Submitted on : Tuesday, January 17, 2017 - 3:38:00 PM
Last modification on : Tuesday, January 17, 2017 - 3:49:44 PM
Document(s) archivé(s) le : Tuesday, April 18, 2017 - 3:07:32 PM
File
419233_1_En_26_Chapter.pdf
Identifiers
Citation
Nazanin Vafaei, Rita Ribeiro, Luis Camarinha-Matos. Normalization Techniques for Multi-Criteria Decision Making: Analytical Hierarchy Process Case Study. 7th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2016, Costa de Caparica, Portugal. pp.261-269, ⟨10.1007/978-3-319-31165-4_26⟩. ⟨hal-01438251⟩
Share
Metrics
Record views
360
Files downloads
1406
