Computer and Computing Technologies in Agriculture IX 9th IFIP WG 5.14 International Conference, CCTA 2015 Beijing, China, September 27–30, 2015, Part I
Conference papers
Design of Integrated Low-Power Irrigation Monitoring Terminal
Abstract : In order to realize low-cost automatic control of field irrigation and water metering, an integrated low-power irrigation monitoring terminal based on wireless data communication was designed. Powered by battery or solar, the terminal could acquire and store data of sensors and water meters in real-time. Taking valve as control object, the terminal can provide safe irrigation strategy based on multiple control logic, such as data overrun, time and manual operation. The detection of fault on-site and reasonable judgment of irrigation can be carried out by using self-check function, querying of local data and remote data transmission based on GPRS and Modbus Protocol. Experimental results showed that the terminal could work stably, and control irrigation water usage accurately with low power cost.
https://hal.inria.fr/hal-01557813
Contributor : Hal Ifip <>
Submitted on : Thursday, July 6, 2017 - 3:49:57 PM Last modification on : Thursday, July 6, 2017 - 3:54:12 PM Long-term archiving on: : Wednesday, January 24, 2018 - 7:33:55 PM
