Conference papers
Is Time Series Smoothing Function Necessary for Crop Mapping? — Evidence from Spectral Angle Mapper After Empirical Analysis
Abstract : Time series smoothing functions have been frequently applied to fit multi-temporal vegetation index for better extraction of plant seasonal/growing parameters. Questions are raised that whether the smoothing is necessary for crop mapping. Four time series smoothing functions, namely, HANTS, Savitzky-Golay (S-G), double logistics and asymmetric Gaussian, were used to smooth 23 MODIS 16-days composite NDVI images in one year. The effectiveness were compared through visual check, correlation coefficient R, root mean square error (RMSE), and local signal noise ratio (SNR). The best smoothing time series NDVI images, along with the original time series images, were then used to map corn and soybeans by spectral angle mapper (SAM) method and their mapping accuracies were compared. Comparison of smoothing results showed that S-G fitted data got the strongest correlation coefficient R, the lowest RMSE and lower local SNR. Comparison of mapping results further showed that time smoothing function does not improve the classification accuracy obviously with the same training sample and same temporal bands. The whole analysis indicates that it is the mapping method that matters more than time series smoothing function for classification precision.
Document type :
Conference papers
Complete list of metadatas
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-01557823
Contributor : Hal Ifip <>
Submitted on : Thursday, July 6, 2017 - 3:50:10 PM
Last modification on : Thursday, July 6, 2017 - 3:54:11 PM
Long-term archiving on: : Wednesday, January 24, 2018 - 2:31:06 AM
File
434296_1_En_33_Chapter.pdf
Identifiers
Citation
Ailian Chen, Hu Zhao, Zhiyuan Pei. Is Time Series Smoothing Function Necessary for Crop Mapping? — Evidence from Spectral Angle Mapper After Empirical Analysis. 9th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2015, Beijing, China. pp.335-347, ⟨1010.1007/978-3-319-48357-3_33⟩. ⟨hal-01557823⟩
Share
Metrics
Record views
104
Files downloads
198
