Abstract : Taxi trip duration affects the efficiency of operation, the satisfaction of drivers, and, mainly, the satisfaction of the customers, therefore, it is an important metric for the taxi companies. Especially, knowing the predicted trip duration beforehand is very useful to allocate taxis to the taxi stands and also finding the best route for different trips. The existence of hyperconnected network can help to collect data from connected taxis in the city environment and use it collaboratively between taxis for a better prediction. As a matter of fact, the existence of high volume of data, for each individual taxi, several models can be generated. Moreover, taking into account the difference between the data collected by taxis, this data can be organized into different levels of hierarchy. However, finding the best level of granularity which leads to the best model for an individual taxi could be computationally expensive. In this paper, the use of metalearning for addressing the problem of selection of the right level of the hierarchy and the right algorithm that generates the model with the best performance for each taxi is proposed. The proposed approach is evaluated by the data collected in the Drive-In project. The results show that metalearning helps the selection of the algorithm with the best performance.
https://hal.inria.fr/hal-01614603
Contributor : Hal Ifip <>
Submitted on : Wednesday, October 11, 2017 - 10:41:03 AM Last modification on : Sunday, November 15, 2020 - 7:40:06 PM Long-term archiving on: : Friday, January 12, 2018 - 1:16:17 PM
Mohammad Zarmehri, Carlos Soares. Collaborative Data Analysis in Hyperconnected Transportation Systems. 17th Working Conference on Virtual Enterprises (PRO-VE), Oct 2016, Porto, Portugal. pp.13-23, ⟨10.1007/978-3-319-45390-3_2⟩. ⟨hal-01614603⟩
