A Novel Locally Multiple Kernel k-means Based on Similarity
Abstract : Most of multiple kernel clustering algorithms aim to find the optimal kernel combination and have to calculate kernel weights iteratively. For the kernel methods, the scale parameter of Gaussian kernel is usually searched in a number of candidate values of the parameter and the best is selected. In this paper, a novel multiple kernel k-means algorithm is proposed based on similarity measure. Our similarity measure meets the requirements of the clustering hypothesis, which can describe the relations between data points more reasonably by taking local and global structures into consideration. We assign to each data point a local scale parameter and combine the parameter with density factor to construct kernel matrix. According to the local distribution, the local scale parameter of Gaussian kernel is generated adaptively. The density factor is inspired by density-based algorithm. However, different from density-based algorithm, we first find neighbor data points using k nearest neighbor method and then find density-connected sets by union-find set method. Experiments show that the proposed algorithm can effectively deal with the clustering problem of datasets with complex structure or multiple scales.
Document type :
Conference papers
Complete list of metadatas
https://hal.inria.fr/hal-01614989
Contributor : Hal Ifip <>
Submitted on : Wednesday, October 11, 2017 - 4:57:44 PM
Last modification on : Friday, November 3, 2017 - 10:24:06 PM
Long-term archiving on: Friday, January 12, 2018 - 3:28:26 PM
File
433802_1_En_3_Chapter.pdf
Identifiers
Citation
Shuyan Fan, Shifei Ding, Mingjing Du, Xiao Xu. A Novel Locally Multiple Kernel k-means Based on Similarity. 9th International Conference on Intelligent Information Processing (IIP), Nov 2016, Melbourne, VIC, Australia. pp.22-30, ⟨10.1007/978-3-319-48390-0_3⟩. ⟨hal-01614989⟩
Share
Metrics
Record views
448
Files downloads
43
